1991 acura integra with b16
Old Oct 1, 2011 | 05:09 AM
doctorash27's Avatar
Default 1991 acura integra with b16
i have a 91 integra with a b16 swap thats chipped and tuned with the HONDATA 100 software. its great off the line and around town but in 5th gear at just over 100mph im a 6000 RPM. any trans ideas like a 6 speed or anything i can do to drop the RPMs at high speeds?
Old Oct 1, 2011 | 03:56 PM
redDAinteg's Avatar
Default Re: 1991 acura integra with b16
There are no 6 speed options available. If you want the rpms to be lower at higher speeds you can swap in a hydro gsr transmission or a cable LS transmission or hydro LS transmission. All of these transmissions will make your car slower, but the rpms will all be lower. To run a Hydro transmission you will need a cable to hydro conversion kit and also cable to hydro transmission mounts.
Old Oct 1, 2011 | 07:02 PM
Hidenplanvew's Avatar
or custom b16/ ls 5th gear trans... not hard to do
aznboi_2
Apr 7, 2009 11:07 PM
scspeed
Transmission & Drivetrain
Mar 8, 2009 06:55 PM
Dev15Bizz
Dec 20, 2008 08:39 PM
Infinite Auto
Feb 14, 2007 09:37 AM
