1999 civic cigarette lighter
Old Sep 30, 2011 | 08:07 PM
RubberGloveBoii's Avatar
Default 1999 civic cigarette lighter
I have a 1999 Honda Civic that the cigarette lighter does not work. We have gone through all the fuses, and it still does not work. Could the wires be bad, or do I have to replace the whole unit?
Old Oct 1, 2011 | 04:19 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 1999 civic cigarette lighter
Did you bother to pull the trim and see if it's actually connected?
Old Oct 1, 2011 | 04:29 AM
thenext's Avatar
20% cooler
It is a simple circuit, so break it down and isolate the problem. Fuses are good? The actual cigarette lighter (the thing that pops out) could be bad. Get a test light on that socket, if there is voltage its the actual lighter. If there isn't, pop off the plastic and get a look at the power and ground.
Old Oct 1, 2011 | 04:31 AM
The Grumpiest
There are cigarette lighters in the 99s? I thought those were all just power outlets? In any case, pull the trim and check the connections.
Old Oct 1, 2011 | 04:37 AM
thenext's Avatar
20% cooler
I don't know if they do or not. I figure it would be the same as any other civic, let alone car. He said the lighter won't work not the socket. It's one thing or the other, if it doesn't have the lighter then he can skip that step.
Old Oct 1, 2011 | 07:32 PM
I dont have the lighter piece. Its mostly the power outlet is what im worried about but looking at what yall have said ot sounds easy to fic. Thanx for the help.
Old Oct 1, 2011 | 08:03 PM
goldfinger1275's Avatar
The cigarette lighter socket is different from the power outlet. The cig lighter wont work on the power outlet. The cig lighter socket on the 96-00 should come with the ashtray.
Old Dec 7, 2011 | 07:47 AM
Tanvirah's Avatar
Default Re: 1999 civic cigarette lighter/ Auxiliary Power Outlet (APO)
I just bought used 2000 Honda civic LX yesterday and checked that cigarette lighter port or Auxiliary Power Outlet (APO) is not working. I want to use this for plugging GPS.
1. I checked with multimeter, there’s no power in socket, wires are tightly soldered into connector behind that socket.
2. Then I tried to find out fuse (both on hood box and one below dashboard). All fuses are ok but some are missing. Don’t have idea how to fix this problem.
3. Wipers, Radio, and doom light working perfectly
Pls help me out and guide me further,
Old Dec 7, 2011 | 10:31 AM
motegicivic's Avatar
Make sure you have the key turn to number 2 or car running for it to work.
Laidbackdriver
Jun 11, 2016 09:25 AM
Gargoyle33
Honda Civic (2001 - 2005)
Dec 23, 2009 09:48 PM
Sr420Det
Jul 4, 2008 11:21 AM
MISFITofMAGIC
Jun 30, 2006 01:39 PM
