what could be done to solidify my 94'?
Old Oct 5, 2002 | 06:11 AM
UseR's Avatar
Default what could be done to solidify my 94'?
Is there anything that can be tightened on the car to make it "like a rock..'? I notice when i drive it it feels a bit loose. Struts are already on my mind, but i think it might have something to do with the chassis. Plz dont say anything about suspension!
Old Oct 5, 2002 | 06:21 AM
4doorH22's Avatar
Default Re: what could be done to solidify my 94'? (UseR)
Was the car in a wreck?
Check all your sub frame bolts. Interior trim might be loose and rattling. Not much you can do for the chassis besides putting in a roll bar/cage to stiffen it or sound deadening material to quiet it. Do a once over of all suspension nuts and bolts you'd be amazed how much play there is due to wear and tear. The bushings are probably due for replacement.
Old Oct 5, 2002 | 06:31 AM
UseR's Avatar
Default Re: what could be done to solidify my 94'? (4doorH22)
Hey would you know what stores would hold bushing, just off the top of your head?
Old Oct 5, 2002 | 04:35 PM
Ideal's Avatar
your local honda dealer.
Old Oct 6, 2002 | 09:40 PM
snoop_bealybob's Avatar
Default Re: what could be done to solidify my 94'? (Ideal)
Check the your control arms (bushings-are the cracked/worn?), and tie rod ends. These are areas that will cause you to feel a "wander". Dealers suck/are crooks. I have an online site that I use (at least half of what a dealer would charge you). I will send you the address if you'd like. I won't post here because I don't want to seem like I'm pushing anything.
[Modified by snoop_bealybob, 6:42 AM 10/7/2002]
Old Oct 6, 2002 | 10:18 PM
WheAs MaI MojO's Avatar
thas what my 02 ex cpe 5 spd exactly feels like. When i go on bad roads, the car feels like its gonna fall apart with various types of squeaks and i can feel the chassis is not too rigid at all.....what should i do?? my car is still under warranty but what can the dealer do??
Old Oct 7, 2002 | 05:05 AM
4doorH22's Avatar
Default Re: what could be done to solidify my 94'? (Pimpin Accord)
That car must be a lemmon because the only Hondas I've seen that feel like they're falling apart are 20 years old and severly abused.
Old Oct 7, 2002 | 05:29 AM
SOHCArchangel's Avatar
polyurethane always helps
Old Oct 7, 2002 | 06:00 AM
UseR's Avatar
Default Re: what could be done to solidify my 94'? (snoop_bealybob)
Hey snoop, ill go ahead and get that address from you, ill send you and IM.
Old Oct 7, 2002 | 06:16 AM
Vexamus's Avatar
Energy Suspensions whole car bushing kit. Best 100 bucks you'll spend.
Old Oct 7, 2002 | 08:38 AM
UseR's Avatar
Default Re: what could be done to solidify my 94'? (Vexamus)
Where would i find one good sir?
Old Oct 7, 2002 | 08:54 AM
4doorH22's Avatar
http://www.nipponpower.com/suspension/bushings/es.html
Their prices aren't the best but service is good. I've made many orders with them, including my E/S kit which I've yet to install.
Old Oct 7, 2002 | 09:17 AM
UseR's Avatar
Hey thanks ALOT.
Matt Isaacks
May 14, 2016 12:20 PM
BuickMike
Jan 10, 2011 09:49 PM
jmai86
Jul 16, 2007 10:40 PM
FastSS
Apr 1, 2003 04:07 PM
Chris_
15
Jun 20, 2002 01:17 PM
