98 civic d16y7 p28 ecu non-vtec sputtering @ 3500rpm
i got a d16y7 with a p28 ecu, that is having a sputtering problem @ 3500rpm, i figure first fuel filter, then ecu, dont have obd1 scanner, do have cel on, any ideas?
jump the connector in the passager kick panel and p28 is a vtec ecu so your going to have codes for vtec solonoind knock sensor and vtec oil pressure switch probably running way rich as the d16z6 has bigger injectors and different fuel maps . why do you have that ecu on a y7 ?
DaddyKin
14
Jul 12, 2011 01:52 PM
