93 Civic:Problems after overheat
Old Sep 30, 2011 | 01:29 PM
Mikes2000civicsi's Avatar
Default 93 Civic:Problems after overheat
hi h-t,
So i was coming home the other night and one of my coolant(heater) hoses finally popped.Instead of calling a tow truck i decided to drive the car the 4 extra miles to home(I know not the best call),with the car at the h for the last mile and the car wanting to rev when i put it into neutral i finally made it home.Next morning i changed the hose,bled the system and put the key in the ignition,no CEL,upon starting the car runs fine for 2 secs then throws a code(which means i cant check it with paperclip trick).Now the car gets 10mpg and on idle it does a putting motion(spurts out of the exhaust).coolant looks fine not milky.Im at work and just decided to ask my fellow honda techs for a online diagnosis,thanks guys
Engine is a d16z6
Notes:
Ran the car overheated(4 miles)
exhaust sputters on idle
Cel only after engine on
Old Sep 30, 2011 | 01:38 PM
Former User's Avatar
Default Re: 93 Civic:Problems after overheat
Not good.
When the CEL turns on and the engine stalls, don't turn the key off. Instead leave the key in ON(II) while you jump the service connector to pull the codes.
Old Sep 30, 2011 | 01:39 PM
grumblemarc's Avatar
The Grumpiest
It popped off and you did not re-attach it? In any case you might be in the market for a new engine.
Old Sep 30, 2011 | 01:41 PM
Originally Posted by RonJ@HT
Not good.
Engine does not stall at all,should i forcefully stall it to be able to pull the code,and will it work?
Just had a hole in a hose which i could not locate at the time
Old Sep 30, 2011 | 01:43 PM
With the engine running, just jump the service connector when the CEL turns on.
Old Sep 30, 2011 | 02:51 PM
furious94ls's Avatar
These engines are usually toast once overheated. At the minimum you need a new headgasket. Never drive w/out coolant.
Old Oct 1, 2011 | 10:47 AM
thanks to ron,i used a paperclip with the engine on and pulled 2 codes,map sensor and tps sensor,i guess coolant got up in the plug,anyway i can salvage them or best to just replace
Old Oct 1, 2011 | 06:33 PM
strategy400's Avatar
You should have pulled over immediately and shut down the engine. A mile in the red? Rebuild time.
Old Oct 1, 2011 | 07:24 PM
92lxsleeper's Avatar
nah you might luck out and be fine. my d15b7 cylinder head was warped all to hell. i stuck it in the oven on 500 degrees for 1 hour and immediatly installed and torqued down and i drove on it a full year with no problems till i swapped the engine.
Old Oct 15, 2011 | 11:01 AM
Update: Swapped the motor out for another z6,used the old z6 intake/tb.now i still throw code 3 and 7,so i switched the throttle body from the new z6 to the old z6 manifold which lead me to just throwing the map sensor code and not the tps,My new question is can using the old throttle body which is dirty inside cause it to throw a map sensor or should i just switch it out and find out
Old Oct 15, 2011 | 11:05 AM
motegicivic's Avatar
Test the MAP, red green wire ( i think) back prob it with a multi meter set to 12V see if you 3 volts with the key to position 2. Also make sure you ground the multi meter's black wire.
Then run on car and same thing back probe and see if you get 1 volt.
Old Oct 15, 2011 | 12:48 PM
i really dont think its the map sensor tho,tried 2 and a new 1 from autozone and still throw the code,
Old Oct 15, 2011 | 03:59 PM
Did you try to reset the code and see if it comes back?
Also check the wiring to the MAP, for some reason I do not think a dirty throttle body will set off a code but I could be wrong, unless the throttle body is different and the MAP sensor you got is the wrong part?
Jvelez1216
Sep 24, 2016 01:01 PM
b20bFourDoorCivicLX
Aug 18, 2013 02:29 PM
drummr6
Aug 22, 2005 10:29 AM
RZFD
20
Jun 12, 2005 02:00 PM
Gant
Sep 15, 2004 10:13 PM
