compression ratio vs head gasket thickness
Old Oct 5, 2002 | 04:30 AM
fastludeh22's Avatar
Default compression ratio vs head gasket thickness
what is the stock thickness of the head gasket? also how much will it effect the compression ratio to use a .043 or a .030 thickness. thanks
edit:this is for an h22a1, guess that would help.
[Modified by 93ludevtec, 9:49 PM 10/6/2002]
Old Oct 6, 2002 | 08:49 PM
Default Re: compression ratio vs head gasket thickness (93ludevtec)
Old Oct 7, 2002 | 05:13 AM
boomslang's Avatar
The stock head gasket is 0.029" thick. For every 0.01" you increase the gasket thickness, you decrease compression by ~0.3.
Old Oct 7, 2002 | 10:59 AM
577HondaPrelude's Avatar
Default Re: compression ratio vs head gasket thickness (Inlinefour)
cool, so it sounds like the turbo guys should get a big fat head gasket.
Old Oct 7, 2002 | 03:54 PM
Default Re: compression ratio vs head gasket thickness (57STS)
is that right!? so the .043 reduces it 4.2 points?! thats the size choices from cometic...
Old Oct 7, 2002 | 05:19 PM
boomslang's Avatar
No.
For every 0.01" you increase over stock thickness, you decrease compression 0.3.
Old Oct 7, 2002 | 08:02 PM
2002TypePshh's Avatar
i.e if those numbers are "about" right with the .014 difference from stock to .043 would be about .42 lower than stock.
Old Oct 13, 2002 | 10:36 AM
Car_Addict's Avatar
Why would you want a big fat head gasket if it decreases the compression ratio, wouldnt you want a bigger compression ratio for more boost? i'm confused..
Old Oct 13, 2002 | 11:11 AM
BoostedH23a1's Avatar
Default Re: compression ratio vs head gasket thickness (Car_Addict)
no u want low compression for turbo. u can have 12:1 compression and still have a turbo say like 5 psi that would be like running 10 psi at 9:5:1 (i know the numbers are not right be u get my point...)
Old Oct 13, 2002 | 11:45 AM
laughinxxx's Avatar
New User
High compression increases the likelyhood of detonation. When you increase the pressure, temperature goes up. High temps in the cylinders induce premature detonation, which blows motors.
Old Oct 14, 2002 | 01:39 PM
Car_Addict's Avatar
Default Re: compression ratio vs head gasket thickness (laughinXXX)
So your saying that if a guy with a turbo, would want a huge head gasket so he could in turn get more psi because there is less compression, (if he wanted more), with the proper tuning and internals?
Old Oct 14, 2002 | 01:52 PM
ya, but there has to be a balance, cause lower compression=lower power, assuming everthing else is the same. most people run about 9:1 w/turbo, but im going w/about 10:1 w/standalone and good tuning
petty$rep
Nov 11, 2006 02:20 PM
Soon_2b_evil
Oct 13, 2004 10:14 AM
Evs-One
Mar 3, 2003 01:09 AM
neumonik
Jan 15, 2002 12:45 PM
