HONDATA K-PRO ECU K SWAP ECU
hondata k-pro K SWAP ECU .... call (786) 236-6751
$850
Main features:
Designed and assembled in USA
USB connection for speed and compatibility
KManager Windows based software for parameter & table editing, calibration uploading and datalogging.
Many built in calibrations for common engine combinations
Built in datalogging to a laptop
On board datalogging memory (2 MB memory, 10-110 minutes datalogging)
Adjustment for different sized injectors, with overall fuel trim.
Configurable for any MAP sensor (to 5 Bar and above)
TPS based table lookup for ITBs
Engine protection from over boost and lean protection.
Expanded fuel and ignition tables, both in rpm and load, to 60 lbs boost and 11,000 rpm (these are not the upper limits)
Launch control with anti-lag
Three multi purpose outputs for nitrous control or similar
Supports lambda tracing from the stock wideband o2
PWM output for boost control
$850
Main features:
