Have you guys seen this???
Hondata just seriously upped the ante for B-Series owners...
http://www.hondata.com/s300.html
Most of you may not care, but I thought I would share anyway...
Check out some of the awesome features...
Main features:
Fits inside the ECU
Built on the proven s100/s200 code base
USB connection for speed and compatibility
SManager Windows based software for parameter & table editing, calibration uploading and datalogging.
Real-time updating of ECU
Built in calibrations for common engine combinations
Built in datalogging to a laptop
On board datalogging memory (2 MB memory, 20-60 minutes datalogging)
Adjustment for different sized injectors, with overall fuel trim.
Configurable for any MAP sensor (to at 5 Bar and above)
Engine protection from over boost and over temperature.
Expanded fuel and ignition tables, both in rpm and load, to 60 lbs boost and 11,000 rpm (these are not the upper limits)
Launch control with anti-lag
Full throttle shift
Two multi purpose outputs for nitrous control or similar
Lambda tracing (with a wideband o2 sensor)
SManager editing software features:
High and low speed 24 x 20 ignition and fuel tables for correct VTEC tuning
Injector size fuel trim
Fuel trim for starting, throttle tip in and individual cylinder trim
Rev limiter with fuel cut or fuel and ignition cut
Full throttle shift
Adjustable VTEC window with load and throttle control
Secondary intake runner control
Adjustable idle speed
MAP sensor type and calibration
Adjustable boost cut with hot and cold settings
Shift light
Closed loop control
Air temperature compensation
Water temperature compensation
Fuel and ignition correction based on gear
A/C shutoff conditions
Closed loop
Two general purpose outputs for nitrous control, dual boost control or similar
On board datalogging trigger conditions
And it is only $595.00!!!
Main features:
Fits inside the ECU
Full throttle shift
Full throttle shift
Shift light
Closed loop control
Closed loop
**** hondata. they dont give a rats *** about there customers... there out for the money and thats it.
everyone has requested TPS and Map for ITB's and they have yet to make that.
Not to mention they wont even offer a discount for Previous hondata customers.
K series users had to beg to get a discount went kpro came out.
Now that S300 is coming out just be prepared to take it up the *** big time.
Stick with Crome. its free and just as good as hondata without getting raped for $600
Re: (JDMlyfestyle)
Yeah.. Stupid capitalists... How dare they build a business "for the money"...
Someone has some anger management issues...
Not sure what K users you know of who are “begging” to get a discount???
Oh yeah.. Crome.. Good times….
Hey let me know when Crome has an onboard daughterboard, that doesn't require chip burning and allows for real time updates, O.K.????
JDMlyfestyle
10-09-2005 11:09 AM
