1995 e36 325is supercharged
Old Sep 30, 2011 | 07:39 AM
silinteg90's Avatar
Default 1995 e36 325is supercharged
Sad to sell but time to move on and try to get something i can use everyday
1995 325is coupe black on black leather 181k on body..been in storage for 1 year. BMW technician owned
5 speed trans
aftermarket modifications:
Active Autowerke c30 M3 supercharger kit meaning has the 85mm pulley and bigger front mount intercooler, approximately 15k on charger
red top bosch injectors..i have the stocks if needed
k&n filter
AA custom chip program to use with non M ecu..also have the turner motorsports chip program if you want to go back to N/A
new rotrex traction fluid
supercharger oil cooler
ASC delete
EWS delete
suspension:
10k miles tokico blue front struts
upgraded upper rear shock mounts
new lower control arm bushings
eibach sport springs
brakes:
5k on drilled/slotted brake rotors on all 4
ebc green fronts and hawk rear pads
front stainless steel lines, i have the rear lines but not installed
rebuilt stock calipers on all 4
exhaust:
custom b&b tri-flo muffler with single outlet tip
custom high flow cats (side by side)
new o2 sensor 1 week old
wheels: 18inch black wheels with polished lip, kumho tires 225/40/18 on rear, Nexen 215/35/18 fronts
interior:
autometer air/fuel gauge on pillar
autometer boost gauge
Alpine speakers
maintenance:
Motor rebuilt, stock internals 15k ago, gaskets, seals etc.
new radiator 5k miles (broken neck)
New water pump metal impeller 5k
fan delete 5k
318i cooling fan switch to turn on earlier 5k
redline water wetter
2 aftermarket fans 1 slim spal puller and 1 hayden pusher 5k
Ice cold a/c
Rebuilt vanos unit 15k
new valve cover gasket 5k
royal purple 5w-30 engine oil
mobil 1 synthetic rear diff and trans fluid
ATE super blue brake fluid 5k
aluminum thermostat housing 5k
upgraded timing chain tensioner 5k miles
ngk plugs 1 heat range colder
sachs clutch/pressure plate/bearing 5k
new starter 5k
DDM Tuning 6k slim hid kit
New serpentine belt 1 week old.
New idle control valve hose. 1 week old.
Blacked out rear taillights/corners and side markers. I have the stock taillights also.
Yellow film over fog lights.
Cannon/weathertech branded floor mats and trunk liner.
Alarm with keyless entry.
Limo tint on rears only.
Premium gas 93 or higher only cause of the chip program.
Absolutely no dead pixels!! Everything in the interior works!
No oil leaks at all from engine, very tiny seep from power steering line, coming from the washer at the pump.
This was my daily driver, 52 miles a day.
Never seen snow.
I am the 3rd owner, I have the original window sticker from 1995 from Knauz BMW along with the brochure.
Service stamps in owners manual.
Clean autocheck history, can give the printout to buyer.
No accidents
Original owners manual in leather binder.
Tool kit is complete in truck.
BMW rechargeable flashlight in glove compartment.
All original keys, 2 master and 1 valet.
Now the bad..please take into consideration that it is 16 years old...but in very good condition for its age..
Rust bubbles near lower part of trunk.
Front end needs paint soon, rock chips.
Ding on pass fender.
Some light scratches on pass side of car from people walking in and out of garage.
ABS light sometimes stays on long but turns off after a few minutes.
Will need 2 front tires.
Will need 1 high flow cat, insides are rattling.
Headliner sagging on some parts.
Driver seat bolster ripped but not bad
more pics..
http://i258.photobucket.com/albums/h...0/bmwside4.jpg
http://i258.photobucket.com/albums/h...0/bmwside3.jpg
http://i258.photobucket.com/albums/h...0/bmwside2.jpg
http://i258.photobucket.com/albums/h...0/bmwside1.jpg
http://i258.photobucket.com/albums/h...winterior2.jpg
http://i258.photobucket.com/albums/h...mwinterior.jpg
http://i258.photobucket.com/albums/h...0/bmwfront.jpg
http://i258.photobucket.com/albums/h.../bmwengine.jpg
please email with any questions or pictures.....asking 6000 obo
Old Sep 30, 2011 | 08:19 AM
forceinducted's Avatar
Default Re: 1995 e36 325is supercharged
bad link
Old Sep 30, 2011 | 08:42 AM
silinteg90's Avatar
thanks! fixed
Old Sep 30, 2011 | 02:49 PM
Grujo's Avatar
power number?
Old Oct 3, 2011 | 07:30 PM
silinteg90's Avatar
offers are welcome..
Old Oct 5, 2011 | 07:17 AM
silinteg90's Avatar
5500 drop
Old Oct 6, 2011 | 10:07 PM
silinteg90's Avatar
hey everyone..5200 friday only...
just remembered..got 15 inch steelies for it too in storage included in the sale....great for snow tires..
Old Oct 10, 2011 | 07:00 AM
silinteg90's Avatar
5000
silinteg90
Oct 10, 2011 07:02 AM
kunt_masha
Feb 11, 2009 10:12 AM
xjohnx
Jul 30, 2005 12:10 PM
xjohnx
Jul 27, 2005 04:17 AM
