Mishimoto Radiator, Fan kits and Hoses offered at B2autodesigns
Hello Guys,
We stock alot of parts from Mishimoto. Which means fast shipping times. We are also running FREE SHIPPING on all Mishimoto parts
We want to earn your business. Check us out!!!
Mishimoto Radiators:
Acura Integra Performance Aluminum Radiator 1990-1993
Acura Integra Performance Aluminum Radiator 1994-2001
Acura Integra X-Line Performance Aluminum Radiator, 1994-2001
Acura NSX Peformance Aluminum Radiator Manual 1990-2005
Acura RSX Performance Aluminum Radiator, 2002-2006
Honda Civic X Line Performance Aluminum Radiator 1992-2000
Honda Accord Performance Aluminum Radiator 1994-1997
Honda CRX Performance Aluminum Radiator 1988-1991
Honda Civic Performance Aluminum Radiator 1992-2000
Honda Civic Performance Aluminum Radiator, 2001-2005
Honda Civic SI Performance Aluminum Radiator, 2002-2005
Honda Civic SI Performance Aluminum Radiator, 2006+
Honda Element Performance Aluminum Radiator 2003-2006
Honda S2000 Performance Aluminum Radiator, 2000-2009
Honda S2000 2000-2009 X-Line Performance Aluminum Radiator
Honda Prelude Performance Aluminum Radiator 1992-1996
Honda Prelude Performance Aluminum Radiator 1997-2001
Mishimoto Fan kits:
Acura Integra Performance Aluminum Fan Shroud, 1990-1993
Acura Integra Performance Aluminum Fan Shroud Kit, 1994-2001
Acura RSX Aluminum Fan Shroud Kit, 2002-2006
Honda Accord Performance Aluminum Fan Shroud Kit, 1994-1997
Honda Civic Performance Aluminum Radiator Fan Shroud Kit, 1992-2000
Honda Civic SI Aluminum Fan Shroud Kit, 2006+
Honda CRX Aluminum Fan Shroud Kit, 1988-1991
Honda Prelude Performance Aluminum Fan Shroud Kit, 1997-2001
Honda S2000 Performance Aluminum Fan Shroud Kit, 2000-2009
Mishimoto Hose kits:
Offered in blue, red or black finish:
Acura Integra Silicone Radiator Hose Kit, 1990-1993
Acura Integra Silicone Radiator Hose Kit 1994-2001
Acura RSX Silicone Radiator Hose Kit, 2002-2006
Honda Accord Silicone Radiator Hose Kit, 1994-1997
Honda Civic Silicone Radiator Hose Kit 1988-1991
Honda Civic Silicone Radiator Hose Kit 1988-1991 B16 Engine
Honda Civic Silicone Heater Hose 1988-1991
Honda Civic Silicone Radiator Hose Kit 1992-2000
Honda Civic Silicone Radiator Hose kit 1992-2000 B16 Engine
Honda Civic Silicone Radiator Hose Kit 2006+ SI
Honda Prelude Silicone Radiator Hose Kit, 1997-2001
Honda S2000 Silicone Radiator Hose Kit, 2000-2009
New!!!
Racing Thermostat:
The Mishimoto Honda racing thermostats will promote greater cooling efficiency throughout your engine. The Mishimoto racing thermostat will significantly lower high engine temperature produced by modified and upgraded turbo applications. Once the engine is fully warmed up the Mishimoto racing thermostat will open up at a lower temperature than standard thermostats, also allowing the coolant to flow through the engine sooner thus reducing and maintaining cooler engine temperatures.
Acura Integra Racing Thermostat, 1990-2001
Acura RSX Racing Thermostat, 2002-2006
Acura Legend Racing Thermostat, 1991-1995
Honda Accord Racing Thermostat, 1990-2002
Honda Civic Racing Thermostat, 1992-2000
Honda Civic SI Racing Thermostat, 2006-2011
Honda CRX Racing Thermostat, 1988-1991
Honda S2000 Racing Thermostat, 2000-2009
Honda Prelude Racing Thermostat, 1992-1996
Mishimoto Fan Switch 80 degree - Honda/Civic/Integra/Accord/SC2000
Mishimoto Liquid Chill Radiator Coolant Additive 4 oz. Bottle
Mishimoto's Liquid Chill Coolant Additive can make your motor run up to 30°F cooler than a standard water/coolant mix. This additive evenly lubricates the metals in the motor for cooler temperatures overall even when compared to water alone. The additive is non-corrosive and also prevents future corrosion. Liquid Chill can be mixed before putting new coolant in your car or directly poured into the already used coolant that you are currently running. Liquid Chill is a great addition for any car be it a street or track machine
Mishimoto Temperature Gauge 1.3 Bar Radiator Cap Small
A perfect replacement for your OEM radiator cap, the Mishimoto Temperature Gauge cap will provide increased pressure tolerance (1.3 Bar), while providing an accurate temperature reading of your coolant.
Carbon Fiber 1.3 Bar Radiator Cap, Small
The Mishimoto radiator cap is rated at a higher pressure and will keep coolant where it needs to be-flowing within the system. The sleek carbon fiber exterior will add an unexpected touch of style. Constructed from hand laid carbon fiber. Rated at 1.3 Bar (19 lbs pressure). Fits most import vehicles.
Mishimoto Oil Sandwich Plate Adapter: In stock
Mishimoto carbon fiber shift ****: In stock.
Please pm us for best pricing:
We offer the full lin up of Mishimoto parts. If you don't see an item listed send me a pm I will qoute you right away.
Member feedback:
Thanks
Adrian
Mishimoto Fan kits:
New!!!
Racing Thermostat:
Member feedback:
Hey just wanted to vouch for these guys legit place I Inquired about priceing and they were they offered the best price i could find, they were verry knowelegable answering any quistions i had pointing me in the right direction and when I asked about a piece I needed they suggested places where I could find it instead of trying to just sell me on something similar that they have that would not be the right piece, much thanks to these guys I got my Radiator verry quickly and am more than happy with it, works great and it comea with mishimoto's warrenty!! Thanks again
Thanks
Adrian
Join us on Facebook: Always got deals going on!!!
https://www.facebook.com/#!/pages/B2...s/165793298063
Thanks
Charles
Thanks
Charles
We also offer Ichiba v1 hub centric spacers. In 5mm, 10mm, 12mm, 15mm and 17mm. 4x100, 4x114.3 and 5x114.3 bolt patterns.
We also offer the Ichiba v2 style. Bolt on spacers. In 15, 17, 20, 22, 25, 27 and 30mm. 4x100, 4x114.3 and 5x114.3 bolt patterns.
Message me for best pricing
Thanks
Charles
Thanks
Charles
