VAFC trouble
Old Oct 5, 2002 | 12:48 AM
TuRbOgSr818's Avatar
Default VAFC trouble
Does anyone have a map for a turbo gsr for the VAFC. my map was erased somehow. and i am having truoble with my car. it's not working rite.
Old Oct 5, 2002 | 08:47 AM
TimoneX's Avatar
New User
Default Re: VAFC trouble (TuRbOgSr818)
You probably re-initialized it. Check your sensor in/out settings. A GSR should be 06/06 as I recall. I cannot help you with your fuel map, mine would not be of much use to you. If you're boosted, I recommend you sell the Vafc and set yourself up with a Hondata S200 w/ boost option. While it's not cheap, the new system is quite reasonable, and properly set fuel & timing curves could save you from expensive problems down the road, not to mention yielding a performance increase and better MPG.
bllabong89
Engine Management and Tuning
Feb 26, 2009 07:13 AM
_Endless_
Jun 20, 2003 10:07 PM
98civicEX
Jul 2, 2002 07:16 PM
dbman96
Oct 8, 2001 11:09 AM
