98 coupe tachometer jumping????? VIDEO INSIDE
Old Sep 29, 2011 | 11:26 AM
Max McNasty's Avatar
Default 98 coupe tachometer jumping????? VIDEO INSIDE
ok so heres the situation. i have a 98 coube with a b16a2 swapped in it on a p72 ecu and i have an 02 sensor code. When im giving the car throttle my tach jumps around like silly.This happens whether its in gear or in neutral. I dont feel it affecting the car all the time only when im in higher rpms and the car will hesitate a little and fall off. i have a vid i will try to attatch. any help is appreciated.
<iframe width="640" height="480" src="http://www.youtube.com/embed/Vhye1PnKJ6M" frameborder="0" allowfullscreen></iframe>
Old Sep 29, 2011 | 11:30 AM
Former User's Avatar
Default Re: 98 coupe tachometer jumping????? VIDEO INSIDE
The tach signal comes from the igniter unit inside the distributor. It may be bad so have it tested.
Old Sep 29, 2011 | 11:40 AM
i replaced it a few months back.
Old Sep 29, 2011 | 11:42 AM
Test the blue tach wire running between the igniter unit and tach. Are all wires inside the distributor clean and tight?
Old Sep 29, 2011 | 11:51 AM
wires are good and tight but i will certainly check again. thanks for the help.
Old Sep 29, 2011 | 03:09 PM
any other advice? blue wire checks out good.
Old Oct 3, 2011 | 01:33 PM
top
74civic4x4
Aug 25, 2010 12:07 PM
Longchamp
Mar 28, 2009 02:38 PM
NewLs'er
Apr 9, 2006 06:00 PM
its WANG yoO
Dec 9, 2003 09:19 AM
Phat_GSR
Oct 10, 2002 04:58 PM
