HELP: Reverse gear won't go in at all
Old Oct 4, 2002 | 11:50 PM
ntt's Avatar
ntt
Default HELP: Reverse gear won't go in at all
My ITR won't go into reverse at all, all of a sudden. It was fine this morning, but after leaving it parked for a while I went to get into it and reverse out of a bay and the gear stick won't even move into reverse.
Tried starting and stopping the car,
tried rocking it forward in a forward gear first,
all other gears work perfectly.
Ended up having to push the car out of the parking bay and I was able to drive home.
Can anyone please help diagnose the problem?
ntt
Old Oct 5, 2002 | 12:04 AM
TypeR 599's Avatar
Default Re: HELP: Reverse gear won't go in at all (ntt)
change your transmission fluid. sometimes mine doesn't go in, i just let out the clutch in neutral, depress it again, put it in first, then into reverse. always worked for me.
Old Oct 5, 2002 | 12:08 AM
ntt's Avatar
ntt
Default Re: HELP: Reverse gear won't go in at all (TypeR 599)
Tried that, as I usually do that when its stubborn.
Its not like the usual problem where you feel it move in a little, hear the teeth mesh a little but not go in.... this time you can't even move the gear stick down at all. Its almost like the bushings are blocking the gear off entirely.
Old Oct 5, 2002 | 12:12 AM
vtec.dc2's Avatar
when was the last time you replaced transmission fluid and what kind did you use? does this always happen - or at random times?
Old Oct 5, 2002 | 12:22 AM
ntt's Avatar
ntt
Default Re: HELP: Reverse gear won't go in at all (vtec.dc2)
I get the car serviced at the dealership, I have to check back on the receipts from my services to see when the tranny fluid was last changed.
The problem only started today, and I haven't been able to shift into reverse at all for the last 2 hours.
Old Oct 5, 2002 | 01:12 AM
EPGONZALEZ's Avatar
check shift linkage..
Old Oct 5, 2002 | 06:45 AM
Bbasso's Avatar
Default Re: HELP: Reverse gear won't go in at all (EPGONZALEZ)
and bitch at the dealer! they probably did not use Honda MTF.
Also why didn't you do your own fluid change?
Old Oct 7, 2002 | 11:53 PM
ntt's Avatar
ntt
Default Re: HELP: Reverse gear won't go in at all (Bbasso)
Dealer just got back to me.
5th gear synchro died, took the gear with it, and that's why it won't go into reverse.
Just FYI.
ntt
Old Oct 8, 2002 | 12:10 AM
B2FiNiTY's Avatar
That sucks.
ge_itr
Mar 28, 2007 12:13 PM
Leo C
Jan 21, 2007 09:07 AM
Leo C
Jun 26, 2006 02:22 PM
