Suspension & Brakes Theory, alignment, spring rates....
Any way to fix handling problem after accident?
Old Sep 28, 2011 | 09:58 PM
Riick's Avatar
Icon2 Any way to fix handling problem after accident?
My old Civic had an accident where the front driver's side got pushed down and back. I got the frame pulled, suspension repaired, and alignment done, but now it feels like I'm going to skid off the road if I take a highway offramp/onramp faster than 25mph (right turn at speed). I am wondering what might be causing this problem and whether it can be fixed.
Some things to note:
- The frame is still slightly twisted. (If the radiator is level, the front of the driver's door is about 1 inch lower than front of the passenger's door. The back of the car leans about 1/2 inch to the driver's side in that situation.)
- There is a tiny amount of play in the passenger-side upper A-arm bearing (less than 1mm), as a result of the way that part was replaced.
Old Sep 29, 2011 | 02:58 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Any way to fix handling problem after accident?
Fix these issues or buy another car.
Old Sep 29, 2011 | 05:43 AM
Riick's Avatar
Tank slap; interesting. What normally prevents cars from getting that in a turn?
Old Sep 29, 2011 | 06:47 AM
98civdx's Avatar
Master Detailer
Post alignment specs.
Old Sep 29, 2011 | 11:18 PM
Riick's Avatar
No alignment after 2nd pull (they said not needed as this pull only moved things a hair if at all)
Alignment after 1st pull:
FRONT
:::::: camber :::: caster :: toe :::::::: SAI ::::: included angle
left : -0.09 deg : 2.5 deg : -0.01 deg :: 8.4 deg : 7.5 deg
right: -1.3 deg :: 3.2 deg :: 0.01 deg :: 8.7 deg : 7.4 deg
spec : -1.0~1.0 :: 2.0~4.0 : -0.12~0.12 : 6.6~8.6 : 5.6~9.6
REAR
:::::: camber ::: toe
left : -0.4 deg : 0.07 deg
right: -1.2 deg : 0.08 deg
spec : -1.4~0.6 : 0.04~0.1
Old Sep 29, 2011 | 11:39 PM
Riick's Avatar
Originally Posted by solbrothers
Tight suspension components. My parent have a jeep that would get a "death wobble" when they accelerated hard and turned the wheel. They replace all the bushings in the front end (a lot of them were trashed because it has a cheap lift kit) and it went away. If you have play in any of your auspension components, it'll shoe at one point or another, yours is showing when you take onramps
Sounds possible given the slightly loose A-arm joint. My records also mention a left control arm bushing is bad but has no play (how can it be bad if it has no play?). But is tank slap possible without vibration or oscillation? I don't get those at all. Instead the car just isn't going quite where I point it; like I'm just ever so slightly starting to skid sideways.
cjames235
Feb 7, 2019 05:24 PM
PhucNguyen57
May 7, 2003 01:09 PM
Solipsist
Nov 15, 2002 11:01 PM
94civicx
Sep 9, 2002 06:54 PM
01PYTypeR#1140
Apr 29, 2002 03:36 PM
