springs for ground controll coilover
Does any one know where to get springs? I need stiffer springs for my ground controll coil overs. I am running them over Tokiko Iluminas (white) shocks. Do I need to know the inner diameter and total length of the spring? This is on a 1996 acura integra.
Thanks!
Thanks!
Ground control sells them seperaly, at like $60 a spring.
I think the ID is almost always 2.5 and the length doesn't matter that much.
I think the standard is 8''F 7''R. That's what my springs are.
Depending on how low you want to be, 8''s would be fine F/R.
I believe you can use those on them if they don't have the lenght rate combo you want in the gc spec springs, not sure what the difference is between the GC spec and the 2.5in spec are, maybe someone will post what it is if anything
mackymcg
Aug 1, 2002 11:07 AM
