DIY: 99-00 Civic Baby Carseat Mounting
So this is what I came up with one day, trying to mount the base of the car-seat really secure to keep my 2months old daughter safely transport.
lower anchors & latch retrofit.
Tools:
Drill/Driver
Metal Frame Screws, to avoid drilling then use regular screw.
2xMetal hinge I found extra from the cabinets
Laptop bag straps which I never use.
you can find similar or better metal hinge, straps and screws at Lowes/Home Depot.
1. There's one screw in the center which holding the bottom seat you need to remove that 10m bolt before you can remove the bottom seat.
2. The best location to mount it is on the passenger side, I first try to mount in the center, but there's the hinge for the two piece back seat rest in the way, so I have to move to passenger side.
I just use two Metal Frame screw and screw it directly to chassis
3. I use the Metal frame screw to screw first to make the hole, then use one of those bumper screws with big flat head extra in my tool box, secure the laptop straps with two screws
4. at this point you're pretty much set!
5. mounting the base! this is what the laptop strap will do to secure the front of the base so it doesn't swing at all
now you have lower lower anchors & latch to secure your base like new car does!
Happy transporting your baby!!!
Tools:
Drill/Driver
That's for mounting second step up car seat for baby older who can sit facing toward the windshield not for infant with base facing the back seat. Also my 99 Civic DX doesn't have those top attachments or lower anchor! if it does, I never had to go this route.
no problem, I will need to look deep into modify a top attachment mount once my daughter get older and time to upgrade to second step car seat...
also what year model was that user guide you got from?
Originally Posted by kyyos24
im just curious, did you bother to read the directions on the base? if you dont have a mount to use youre suppose to use the seatbelt
with it install like that myself and my wife don't feel it's safe enough with it swinging too much on turns/stop, take off. So I'm combining that with the base secure. it wouldn't hurt to make it more secure then the limited design of car and car seat.
I didn't see any on my 99 Civic DX: 4d Sedan but will triple check that today after I get home from work.. I'm 99% sure there isn't one for my DX.
i have them in my 2000 CX hatch. ive always wondered what they were for, i thought they were for cargo. so how does it work exactly?
Nice to know! probably they start having it on 2000 model... those could be nice to use to secure your sub-woofer! lol, that's my next mod on my tC, it got 6 anchors & 6 latch more than what I need to secure the car seat on a coupe.
RonJ is right. in 00 the child seat anchors were made mandatory. They are options on all 96-99 civics. If you look in your owners manual the part number is printed there for you if you wanted to order them.
don't you think it's time to start driving like adult slowing down, on turns, braking and acceleration???
wow!!!, you think you are making it safer for your daughter by using non load tested bumper screw and self tappers into sheet metal? i have 2 kids and belts work just fine. you just have to get in the car and kneel on the base and pull hard on the belt it should tighten up and stay tight.
