GC/Koni Spring Rate Advice
First off, I know that this has been discussed a TRILLION times. Dont reply telling me to search around, because I have and am very close to narrowing down to purchase a custom spring rate GC and Koni Yellow shocks. Just treat this thread as spring rate advice specific to me.
I am not totally clueless in the spring rates I want. I am very close to choosing them however needed to seek further advice. The spring rates that I am contemplating are 450lbs/in front and 350lbs/in rear or 425lbs/in front and 325ish rear.
Is 100lbs/in difference from front and rear rates too much? Should it be closer?
I know the front of the car is heavier than the rest and needs a higher spring rate so i dont bottom out. I know OTS Koni's max out at around 500lbs. I know i dont need camber kits.
What I want:
-A finger to no finger wheel gap
-Decent ride quality (which is why i dont want too high of spring rates)
My current setup:
-Strictly Daily Driver commute from Vallejo to Napa with seldom spirited driving.
-Stock suspension
-15in GSR Blades with Kumho 195/50/15
If there is any further information with my setup or driving that you need to know to help me, please ask me.
Thank you for all your input,
Hopefully with all your answers I will be able to purchase, install, and post pics
What I want:
My current setup:
-Stock suspension
You wouldn't notice a difference in either setup with rates that close to each other as far as ride comfort goes.
I would go for the higher front rate. I've got 350lb front springs and it's really too soft.
And koni's don't "max out" there is just an optimal range for damping. Saying they max out implies they might blow or something. Plenty of people have ran 600ll rates on konis for years. They can just live with an underdamped shock.
You sound a lot like me, daily driver but you want to maintain some level of comfort. I've got 350/350 now and wish I had 450/350.
Thank you very much, I knew my research paid off, i just needed to acknowledge that what I was doing is correct. Hopefully in the next month or so I will be able to purchase, install, and post pics. I'll go with the 450F/350R. Thank you very much!
Why? Because I am tired of the back breaking Ebay garbage and want something that rides/ handles correctly while still maintaining a decent ride height. Gotta look all hellaflush to be a cool kid, ya dig?
Ok, I'm a noob, so this might be a dumb question. I'm wanting to put Koni yellows with GC on my car. where should i look for springs? What brand? Are springs a universal thing or are they designed specifically for each vehicle?
Message THMotorsports in the sponsor marketplace for the best deal:
https://honda-tech.com/forums/wheels-tires-brakes-suspension-48/koni-shock-ground-control-coilover-combo-2028746/
The GC kits come with Eibach springs tailored to your vehicle, you can't just install any spring as they are all different sizes and rates. When you buy the GC coilover kit you can either buy their off the shelf standard rates, or ask for custom rates.
Furthermore, if you are looking for 1 to no finger gap, you'd better go with a 400+ front spring rate, ideally 500 if you don't mind a harsh ride. Being low your tires will rub the upper fender wells and you can't be low and not rub AND have ride comfort. I'm running 500 front and 400 rear, it's harsh but I rarely rub and I'm tucking a little bit of tire.
I originally had the off the shelf 340/250 rates and I constantly rubbed over any big dip. It was frustrating and was way too soft for my tastes.
400 might not be enough. I scrub my tires on dips and bang my oil pan on driveways in cul de sacs no problem with 350lb front rates with a similar ride height. I'd recommend at least 450.
from what I gather on this thread and if you don't mind me asking, the higher the spring rate (stiffer ride), the lower the car? What I want is around 1" lower than OEM for exclusively DD, no racing but for comfort/pothols. So can I get Koni/GC combination with 450F/350R or I need to get a lower rate (like 400F/300R)? Thx.
Either setup will work great for a 1'' drop. A 350R generally is a great spring rate for a DD that may see some sprited driving. I run 350lb's in rear, they deffinetly are NOT that bad. However, some people are different. My buddy wont ride in my car, as it's too stiff and hurts his back. (650F 350R) But, for me it's fine for a DD, as long as you can avoid the really bad roads/bumps.
Also, 50lb's truely wont make that much difference in ride quality, if any at all.
Indeed, at least that's what I think it is. The weird slope-y curb that my buddies driveway has is particularly steep for some reason. Never had it happen at my house. And with a sudden drop the front of my car drops a bit. 350lbs is a bit soft for the front, imo.
I do damn near tear my lip off trying to get into my garage, if I am not careful.
The thing about spring rates is that its all subjective. What is "too stiff" depends on what your used to and what you expect. Its not so much of a big deal on a track car as your lap times will tell you if you've made the right decision. I personally prefer a softer setup that allows me to get my moneys worth out of my dampeners.
