GC/Koni Spring Rate Advice
#27
Re: GC/Koni Spring Rate Advice
This is a thread for spring rates not car height.
Sounds like some of you are thinking xxx lb-ft/in. spring = xx" drop.
If your spring rate is higher (stiffer) you can go lower than say a spring that is 100 lb-ft/in.
less. Doesn’t necessarily mean you have to make it as low as possible.
#28
Havent updated the thread for a while, I made my decision back in November and got 430F/330R, the ride is amazing and is a little more rough than stock IMO, im 5'3" 115, maybe thats the reason lol. Full stiff, is has a real noticeable difference.
#31
just ordered koni gc today from thmotorsports and got the off the shelf rate for 95 civic coupe. im wanting to ride at about of a finger gap, with 205 40 16 now im thinking i should have got higher rates, i hope it rides okay with these rates being lowered somewhat
#32
Yes, you should have have got higher spring rates, at least in front.
#33
^Thats what i got, im waiting until spring to see how they feel though. From the sounds of it, 450/350 is a good combo of street/track use. I consulted some representatives from Ground Control before coming to that decision.
#35
#36
you could run into scubbing issues in corners. The extra 100lb's or so will deffinetly help the front end.
IMO the OTS rates are just too low to begin with.
#37
thanks that makes me feel better. so what does the numbers mean? would 450 be 450 pounds per inch of travel? and does anyone know of a close ratio of weight distribution in these cars? (would it be like 70% weight of total car on front wheels 30% on rear for example)
#38
450.8.2.5
450lb 8'' long 2.5'' wide
Means it taks 450lb to compress the spring one inch.
#47
#49
