94 Civic Ex. Will not start occasionally after short drive.
Old Sep 27, 2011 | 06:18 PM
jakescakesz06's Avatar
Default 94 Civic Ex. Will not start occasionally after short drive.
This is a very complex problem I've been having and I need some help diagnosing it.
Symptoms:
The car will start fine, but after a short drive, and then being parked for a few minutes, it will not start or stalls on the first start. This has happened a lot at gas stations after filling up. I then have to wait a few minutes and try try again (usually giving it gas) until it decides it wants to start. Sometimes it will start then die as I give it gas.
Other Noteable Issues:
Minor exhaust leak somewhere between exhaust manifold and cat.
I notice the coolant reservoir gets low very quickly and I have to top it off.
Have replaced the following components:
O2 sensor
Distributor Cap
Rotor
Spark Plugs
Spark Plug wires
Ignition Coil
Recently had CEL 6 - I replaced the ECT sensor and CEL is gone.
No CEL codes showing up, but it will not start on occasion. The only other component I can think of is the igniter inside the distributor.
I am baffled any help for a noob like me?
Old Sep 27, 2011 | 06:39 PM
Bipolarcivic's Avatar
Default Re: 94 Civic Ex. Will not start occasionally after short drive.
have you checked your compression?
Old Sep 27, 2011 | 06:46 PM
altfuelneeded's Avatar
Main Relay!!!!
solders crack,
gets hot and separates
and no more continuity to fuel pump
happened to me awhile back
could not be the problem but hondas are notorious for the main relay, and symptoms are what u describe
Old Sep 28, 2011 | 03:17 PM
I have not checked compression.
I've read a little on the main relay, the symptoms do sound the same. I pulled it out and took a few cell-quality pictures. Not sure what to look for, there is a browinish stain all over, other than that the solders look decent??
Old Sep 28, 2011 | 05:08 PM
frankenghia's Avatar
It does sound like a main relay. Test it. Replace it.
Old Sep 28, 2011 | 08:46 PM
if you have a multimeter get a manual and test the points but usually the cracks are smaller than the eye can see. like frankenghia said test it. or replace it
Old Sep 28, 2011 | 10:45 PM
virgineg6's Avatar
The brown stuff is just flux, its used to help the solder stick better.
Old Sep 29, 2011 | 05:42 AM
redm3turbo's Avatar
Main Relay....
In 1999...I had a crx that had the same probably. Drive the car to the store, go inside....3 mins later go out, and no start.... drive to school, let the car sit for 3 hours...it'd fire right up.
I replaced, and replaced and replaced parts trying to solve it...even took it to Honda 3 separate times and spent 1000+ for it to keep happening. Then I found out about the main relay. 10 mins later and $40 bucks...and all my problems went away.
Old Sep 29, 2011 | 09:57 PM
Where would be the best place to purchase an OEM one? Part #?
Unless the ones at Advanced Auto are good enough.
Old Sep 29, 2011 | 10:10 PM
First.EG's Avatar
got mine from autozone for 40 bucks been good for year no problems at all.
Old Sep 30, 2011 | 01:16 AM
HondaPartsHero's Avatar
Technical Hero
http://techauto.awardspace.com/civicrelay.html
Old Sep 30, 2011 | 02:26 AM
BryanM.'s Avatar
Resident Gearhead
[IMG]http://i870.photobucket.com/albums/ab265/jakescakes2/IMG_20110928_171102.jpg[IMG]
[IMG]http://i870.photobucket.com/albums/ab265/jakescakes2/IMG_20110928_171026.jpg[IMG]
I see a couple bad joints on there. Let me know if you want me to point them out. I just re-soldered a couple of these yesterday, one of them wouldn't prime the pump, and it had the same bad joints as yours.
And the brown coating isn't exactly flux it's a protective coat (smells like pine when burned). Scrub it lightly with a wire brush and acetone and it will come off, if you want to re-solder it.
Old Oct 1, 2011 | 09:24 AM
Sure, you can point them out. Won't hurt to re-solder them and see if it solves my problem before I purchase one.
94_ex
Jul 28, 2010 06:10 AM
tedo2007
13
Dec 4, 2009 09:58 AM
LiL JoN
23
Jun 22, 2009 09:36 AM
spacin
Dec 27, 2007 11:21 AM
jstlsn
Oct 14, 2004 12:59 PM
