94 accord factory foglights
whats goin on fellas, i have a 94 accord with factory foglights, i wanna know how to take the bumper of but my bumper light bolts are rusted out, does anyone kno how to take them out without breaking the light??
You do not need to remove the fog lights to take off the bumper......
Remove the turn signals and access the bumper beam bolts there (4 total)
1 screw at the top of each bumper corner/fender (by corner light)
2 bolts at bottom of bumper on fender liner/bumper
Remove grill
clips along bottom
Should come right off
Remove grill
clips along bottom
no i kno how to take the bumper off, im tryin to get to the foglights, but the amber bumper light bolts inside the bumper are all rusted out, im tryin to the the bumper lights out to get the bumper off
The foglights again, are not going to help you take off the bumper - the 94/95 foglights are just screwed in (4 screws) then have a clip to the wiring harness.
The turn signals in the bumper are held in by a single screw you can access from the lower bumper grill through a small slot.
Taking off the foglights are not going to help you at all.
*edit*
The reason I say they won't help is because there is a bolt on the other side of the bumper bracket where it bolts to the frame. You could potentially get one of the two bolts out but the further one would be a pain in the ***. I also would think if your turn signals screw is rusted up, the foglights are going to the same if not worse.
*edit*
yeah ikno the turn signal in the bumper have a single screw but there rusted n i cant get them out, i need those screws out so i can remove the bumper but i dont wanna break the lights
i got the foglights removed, turns out theres no need to remove the bumper, there r 4 bolts on each foglight that connects it to the bumper once thats removed the foglight comes right out
gsrpedro
Feb 28, 2007 08:23 PM
