05-06 tranny with 02-04 ecu harness add S2k
I see alot people still having problems mph on 02-04 harness kpro ecu and s2k not working. I'm going to show you Guys a simple way to make everything work !
Parts needed
05-06 tranmission with 05-06 senser
Radio shack - +5V Fixed-Voltage Regulator 7805 ( cost $1.80 )
Maybe add S2k cluster
All you have to Repin the plug at the tranny and add the voltage Regulator!
When done it's going to look like this -->
Step 1: Remove all the pins out of plug on the tranny. Going to have 3 wires, 1. Black , 2. Black/yellow, 3. White/green.
This where you going to add the voltage regulator
Bend the pins like this
With a knife cut a small part of black wire and connect middle pin of voltage Reg. This wire is the ground
On the out side of the voltage Reg. Cut Black/yellow wire and solder the wire on each end. It doesn't matter on which pin u use. - what we doing is Control voltage that is on the black/yellow wire. 02-04 harness n ecu send 12v though this wire! 05-06 needs 5v!
For protection all the wires I use high temp silcone
Last part
The white/green wire is signal. Repin the 3 wires back the plug. In this order
1.Black -Ground
2.white/Green =Signal
3.Black/yellow +5v
All done, it should look like this!
Parts needed
Last part
1.Black -Ground
3.Black/yellow +5v
So what are you saying "Honda-tech" doesn't support k20 engines? Talk to your MOD and request it, because you guys don't want to be stuck in past!
As in the word "Honda" mean D B H and k doesn't mean what you have. It's what you drive!
UNKNOWN_MEMBER
Dec 20, 2008 02:58 AM
LshatchTurbo
Oct 13, 2001 05:16 PM
