prelude problem! (sorry if this isnt the right place to post)
Old Sep 27, 2011 | 11:24 AM
Honda kidd's Avatar
Default prelude problem! (sorry if this isnt the right place to post)
Okay so when i down shift, my gauges and tach completly zeros out. when im still moving and its in gear! When that happends the radio turns off and the abs is on. anythoughts?
Old Sep 27, 2011 | 11:32 AM
94ludeking's Avatar
Default Re: prelude problem! (sorry if this isnt the right place to post)
Have you tried running the code? I assume if it comes on it's for a reason. Is there any other lights on?
Old Sep 27, 2011 | 11:54 AM
andoxviii's Avatar
Have you been messing with any of the wiring in your dash?
Have you installed a new stereo recently, or alarm system, or modified ANYTHING before this began happening?
Old Sep 27, 2011 | 12:45 PM
AWDManiac's Avatar
Just a thought but it seems that when you down shift you are putting the car under load, which means more amperage draw from your alternator. Test your alternator with a multimeter while running and see what volts you have. You should be between 13.8 and 14.4 (This is with no load on the car, IE. a/c, heater etc.)
Old Sep 27, 2011 | 01:17 PM
mike541's Avatar
I just posted the same thing on another thread, but check the green plug on your alternator/gen. for CORROSION. Clean it good.
Old Sep 27, 2011 | 03:09 PM
AWDManiac's Avatar
Haha well glad someone thought the same thing
89LSED
Sep 11, 2010 12:06 PM
H23forlife
Jul 28, 2007 02:19 PM
manyakiexpi
Oct 24, 2006 04:57 PM
CTR-GSR
Oct 12, 2006 08:46 PM
precord96
Feb 18, 2004 09:13 AM
