negative offset please!
Old Sep 26, 2011 | 03:55 PM
tailoredtune's Avatar
Default negative offset please!
I have been looking to get some wheel for my 88 civic ef hatch with a negative offset so that i can have a wider stance and the flush look. the problem is that i cant find wheels online with negative offsets. do i need to get the wheels stretched or do yall know where i can get some?
Old Sep 26, 2011 | 06:11 PM
toyomatt84's Avatar
Sanji
Default Re: negative offset please!
I can already tell where this is going.
From the Forum Rules and FAQ:
10. Do not ask about "stretching" tires onto wheels that are too wide.
All such topics will be locked. Tire manufacturers determine the wheel widths onto which each model and size tire can be mounted safely, and you can find the range of these wheel widths in the specs on their websites as well as those of retailers like the Tire Rack. Mounting tires onto wheels outside this range of approved wheel widths is unsafe because it can, and often does, result in the buildup of excessive stress and heat in the tire sidewalls, which can lead to the tire "popping the bead" and/or tire failure. Make sure your tires are mounted on wheels whose widths are within the approved range.
jjstarkey
May 26, 2011 05:30 AM
mrbkelley
May 22, 2011 07:08 PM
400whp
May 27, 2009 03:13 PM
cecknight
Jan 13, 2008 07:21 AM
Stewie
Dec 4, 2003 07:34 PM
