Car loses power when clutch pushed in
Old Sep 26, 2011 | 07:19 AM
ArithMEHtik's Avatar
Default Car loses power when clutch pushed in
The car is a 00 civic si and i was driving it last night, the clutch started to vibrate really bad when I would push it in, it stopped and now it makes a hissing or rubbing noise and the car loses power at idle and dies when I push the clutch in. Anyone know what this is? It's a stage 2 clutch on a b16 tranny stock flywheel. Lsv bottom end b16 head some mods not much don't know if you need to know the setup or not .
Old Sep 26, 2011 | 09:51 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Car loses power when clutch pushed in
"Stage 2 clutch" doesn't tell us anything. Pull the transmission.
Old Sep 26, 2011 | 10:08 AM
I wouldn't be on this forum if I could do that right now. It wouldn't really matter if it was stock or stage 2 would it? I am just giving details.
Old Sep 26, 2011 | 10:15 AM
FPR's Avatar
FPR
Your transmission gears could be ground down in some parts or just not catching fast enough.
Old Sep 26, 2011 | 10:18 AM
It happens when I'm in neutral at idle, it drives fine the vibration stopped out of no where.
Old Sep 26, 2011 | 10:43 AM
FPR's Avatar
FPR
It could be a fuel line just not deciding to pump when in neutral, not sure about the clutch part though
Old Sep 26, 2011 | 10:52 AM
The Grumpiest
A hissing or rubbing sound wouldn't be caused by fuel pump/lines.
How about giving relevant details then? If it's the clutch OR transmission you can't do anything about it until you pull the transmission and inspect both. If you can't do that then that's another problem entirely. Right now the only thing you can do is listen to the noise.
Are you getting any CELs when it happens?
Old Sep 26, 2011 | 11:18 AM
What relevant details do you want? No cels at all. No one has ever heard of this or experienced it before? I plan on dropping the trans when I can.
Old Sep 26, 2011 | 11:21 AM
The Grumpiest
Then there's nothing to be done until the transmission is dropped other than making sure of the source of the noise and that it's not coming from somewhere other than the transmission.
Old Sep 26, 2011 | 11:49 AM
It only happens when I push the clutch in. I don't think it would be from something else?
Old Sep 26, 2011 | 11:51 AM
The Grumpiest
For the third time. Until you pull the transmission there's nothing you can do except listening to the noises.
Old Sep 26, 2011 | 01:47 PM
FPR's Avatar
FPR
"A hissing or rubbing sound wouldn't be caused by fuel pump/lines."
It could be for the loss of power, maaybe. So many things can be wrong cause of that. lol
"For the third time. Until you pull the transmission there's nothing you can do except listening to the noises."
Vague
13
Jun 2, 2015 05:45 AM
LU!SKEY
Aug 19, 2010 10:23 AM
aLlmoTorcoUpe
Honda Civic (2001 - 2005)
31
Nov 2, 2009 02:25 PM
hitvtecgetloud09
Aug 6, 2005 08:55 PM
J MaCk gSR
Jan 22, 2003 04:55 PM
