Honda civic died
Old Sep 26, 2011 | 06:06 AM
dontbeahero13's Avatar
Icon6 Honda civic died
I began driving and heard a loud clicking noise. The higher the RPM went the louder the clicking noise became. I turned around immediatley and when further down the road and engaged the clutch the vehicle died instead of goin to the normal idle. I was still in the middle of busy street so and was rolling so I rolling started until the next light. I continued to do this but when it died the second time the wheels locked up and could no longer push start. When I popped the hood and attempted to start it made a tick noise but no crank. Also the wire from my battery to starter began to smoke. Any ideas?
Old Sep 26, 2011 | 06:08 AM
Former User's Avatar
Default Re: Honda civic died
Car? set up?
Is there any oil in the engine?
Old Sep 26, 2011 | 08:54 AM
it was low on oil so i put more in, it still wont crank its a 2000 ex with a swap for b18c
Old Sep 26, 2011 | 08:55 AM
You may have seized the engine. Put the transmission in neutral and then try to turn the crank pulley. Will it turn?
Old Sep 26, 2011 | 08:59 AM
Im not sure and I wont have acess to my car, but when i tried to push start it the wheels will not turn so i assume that it wont turn
Old Sep 26, 2011 | 09:08 AM
Linked's Avatar
these sound like classic symptoms of a seized engine/ spun bearing
what was the oil maintenance the car undergoes, every 3k miles? do you have any leaks/ burning oil
the primary cause of seized engines are from lack of lube( either you've ran it dry or ran it contaminated with coolant or past the 3 month lifespan)
Old Sep 26, 2011 | 09:10 AM
Im not too familiar with honda/motors i bought as is any ideas on how to fix?
Old Sep 26, 2011 | 09:12 AM
Theres a good chance i ran it dry but i swapped it every 3k
Old Sep 26, 2011 | 09:22 AM
It also doesnt attmempt to start, if the motor was siezed it would make an attempt to start i beleive
Old Sep 26, 2011 | 11:09 AM
Sounds like you should start shopping for a replacement engine.
Mr.Pickle
Honda Civic (2006 - 2015)
Sep 24, 2019 10:02 AM
Jade LaMontagne
Honda Civic (2001 - 2005)
Aug 30, 2018 08:43 AM
surrealx
Jul 24, 2011 11:28 AM
accord2civic2prelude
Nov 12, 2010 11:07 PM
SupraRXZ
13
Feb 21, 2006 08:04 AM
