The length ITR springs?????????
Well I'd say SEARCH...
BUT.... he probably already has, found the different weights, now he just needs the height. ...... Anyone?
Later.
Later.
maybe he bought/will buy some ITR springs and wants to verify they're real?
thanks for the front pics, any rears?
so the front ones are about 13.5" inches in length? (according to the pic)
[Modified by HappyIntegra, 1:36 AM 10/14/2002]
The rears are just a smidgen shorter than the fronts. They have a 3 color pattern on the coils...something like purple, green, white or blue. They also have rubber around the top two or three coils.
Front springs
top: gray
middle: blue
bottom: purple
Rear springs
top: blue
middle: green
bottom: purple
From this pic (these are genuine ITR springs: pic found on Honda-Tech)
So the ones on the left are FRONT, right side are REAR springs?
From the measurements of the 1st pic, the front ones are 13.5 inches, so the rear ones would be like.. 12.5 inches?
What about the RUBBER (sleevings?) on top of 2 or 3 of the springs? I can't really see the rubber in the above pic. Can someone help me spot them? (Are the rubber supposed to be on the top of the 2 Front or Rear springs?)
Thanks if you guys know and can help me out
The taller ones are for the front. Shorter ones for the rear.
You can always tell which end is up by looking at how the coil ends are trimmed. The flat side goes up so that it can mount flush with the spring hat.
In the picture, the side facing up is the side that should face downwards in the shock.
just wondering. Are those stock ITR springs the same as 94-01 regular non-ITR integra spings (eg. GSR)?
If they are different, what is specifically different between them? Do the non-GSR springs have 2 rubber sleeves attached to the rear springs as for the ITR ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtraFastCRX »</TD></TR><TR><TD CLASS="quote">he wants to know how much it will drop his car from a stock gsr height.....
it's like an inch....</TD></TR></TABLE>
actually it's .5
actually it's .5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicS »</TD></TR><TR><TD CLASS="quote">can anyone answer my easy question please?
the useful SEARCH function on this board was implemented for a reason noob.
juniordc2
Suspension & Brakes
May 8, 2005 01:50 PM
B18C5-EH2
Sep 14, 2002 10:41 AM
