93 Del Sol low idle and runs a little rough
I took it in to get diagnostics and they said my PCV valve was bad and my alternator was going out. I replaced the alternator and replaced the PCV valve but Im still having the same issues! The car idles very low (around 300-500 RPM) and sounds very rough. And when I give it gas it kind of sputters a little.
Any ideas as to hwhat my issue or issues could be?
The old alternator was putting out 3 amps. And when I activated any kind of power the RPMs would drop even lower and the car would almost die! But I replaced that alternator with another one that works fine. But no, I havent checked the voltage of the new alternator. I just had my battery chcecked and thats fine too.
take the distributor cap off and make sure there arent any carbon deposits (brown dust), make sure the points arent corroded on the cap, check the rotor and while you got it open look at the wiring and make sure nothing is burnt, loose or cut if thats all good then get a manual and a multimeter and test the coil and icm. Hope this helps
fuel filter , check or replace dizzzy cap and rotor(clean the 4 terminals with a clean wire brush), clean/test or replace IACV, clean TB. make sure the plugs are gaped to spec.
i would check the ignition timing first.
Thanks for all of the suggestions. I will replace fuel filter, distributor cap, and clean my throttle body and get back to you guys with results.
Does the CEL work?
z0mby
17
Dec 5, 2011 09:23 AM
