Anyone have experience installing different door locks & ignition in an EH hatch?
Anyone here have experience in doing this? Just wondering if it would be a cost/time friendly thing to do seeing as just about any civic key will open the lock and turn the ignition.
Its not hard at all
No harder than anything else anyway..
Question is, is it worth having your money pit open for anyone to take?
Ignition lock is easy. It's a pin and a latch you have to deal with to pull the cylinder out. Doors are an hour each maybe. It's an afternoon project at worse. If something doesn't go well, you can put your old handle back on and just grab the rod for the lock and lock it from the inside and someone can't open it from the outside.
look in the FAQ. There is a write up in there on doing the door/trunk locks. The post has part numbers you need as well.
spooncivic1
Dec 15, 2021 09:11 PM
oes
Dec 9, 2003 06:38 AM
