RHD steering rack on LHD subframe
Old Sep 24, 2011 | 03:16 PM
92lxsleeper's Avatar
Default RHD steering rack on LHD subframe
converting my car to RHD, modifying existing firewall instead of swapping in new one. Will a RHD steering rack bolt in to a LHD subframe, or do i need the whole frame. I can get the whole subframe from england for $84 plus shipping, but if i can use just the rack, i can get a lot cheaper shipping obviously.
Default Re: RHD steering rack on LHD subframe
note- its a 97 ek hatch, and the subframe/rack im getting would be from an ITR. shouldn't matter tho
Old Sep 24, 2011 | 03:30 PM
grumblemarc's Avatar
The Grumpiest
RHD? Good luck through those drive-thrus.
Old Sep 24, 2011 | 03:33 PM
98civdx's Avatar
Master Detailer
I am almost 100% positive you would need a RHD subframe/rack.
How in the world are you modifying your firewall for RHD?
Old Sep 24, 2011 | 03:41 PM
well on the ek its a symetrical firewall in terms of shape. im welding up the old holes for the MC and clutch MC, creating them on the opposite side, cutting the hole for the blower motor, welding up the old one. the only harder part, is cutting off the drop out where the steering rack goes through the firewall and adding that to the other side. in terms of strength, i believe the structure of the car will be better doing it this way than to cut the entire firewall out and replace it. plus i get to keep my windshield in so that saves time.
plus i dont have to tamper with the vin on the firewall. big no no in rhode island lol
Old Sep 24, 2011 | 03:42 PM
and i have to figure out how im gonna change the wiper over to RHD. i'll figure something out.
Old Sep 24, 2011 | 03:43 PM
drive backwards
Old Sep 26, 2011 | 01:06 PM
http://youtube.com/watch?v=iOI_pC8NxKU
here is what i've accomplished so far. pedals are mocked up. need to make backing plates from steel to weld in the holes so its a perfect fit. of course its not gonna look like factory, and i need to modify how the pedals are so they go to the left a bit. a torch and a mini sledge will work.
note - this is not gonna be a 100% oem conversion obviously. I'm showing how i would do this on a budget, and maintain the cars structural integrity without risk of my welding skills failing on the firewall swap.
Sprockets
Jun 27, 2016 07:25 PM
El_cOuZiN
Apr 3, 2010 09:59 AM
Stinkycheezmonky
Sep 12, 2007 07:07 AM
project 2two9
Nov 17, 2006 08:06 PM
project 2two9
Nov 17, 2006 04:18 AM
