Beeping Sound!
Old Oct 4, 2002 | 06:53 PM
whagkangmakulet's Avatar
Default Beeping Sound!
Everytime I start my car and then open the door, it start beeping and it wouldn't stop unless I shut my Engine off. Does this ever happen to anyone? This just started recently.
Old Oct 4, 2002 | 07:24 PM
kyler's Avatar
Default Re: Beeping Sound! (whagkangmakulet)
i havent seen it but make sure that your door switch isnt showing ground(-) when its pushed in (like it would be if the door were closed)...
Old Oct 4, 2002 | 07:49 PM
slowman's Avatar
I took way too long
it might be the beeping thing of the passenger seat belt not engaged or something. my honda beeps like a ****.
Old Oct 4, 2002 | 07:55 PM
Cereal_Killer's Avatar
hmm mine happens everytime i hit a bumpr real hard or corner REAL hard. anyone have some tips for this it gets annoying.
Old Dec 15, 2006 | 08:01 AM
StickyGreen's Avatar
back from the dead because my car is doing that exact same thing.
does anyone know where I can remove disconnect that thing that creates that noise?
TIA.
Old Dec 15, 2006 | 08:12 AM
MEDIEVIL's Avatar
that one fuse..........
Old Dec 15, 2006 | 08:13 AM
user 72830283's Avatar
the noise is coming from your rear view mirror....right above your mirror you have this little sover...pop that off..and you'll see the led's for the seat belts...just remove that whole module if you want....i had the same problem...and i removed it...end of beeping. unless you care abt the seatbelt notifications
edit: or yea..you can remove the fuse as well..
Old Dec 15, 2006 | 08:21 AM
Default Re: (pr3d)
thanks, i'll try that..
just curious tho.. what fuse are you talking about? can you guys elaborate a little on that?
thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr3d &raquo;</TD></TR><TR><TD CLASS="quote">the noise is coming from your rear view mirror....right above your mirror you have this little sover...pop that off..and you'll see the led's for the seat belts...just remove that whole module if you want....i had the same problem...and i removed it...end of beeping. unless you care abt the seatbelt notifications
edit: or yea..you can remove the fuse as well..</TD></TR></TABLE>
ksettles619
Apr 27, 2012 11:49 PM
halnuaimi
Honda Civic (2006 - 2015)
Nov 28, 2011 10:01 AM
Khmi
Aug 18, 2009 07:08 PM
beoy9
Jul 10, 2009 12:43 PM
