Good How-To on Goodridge SS Brakelines?
Follow the helms instructions. Don't torque the banjo bolts any tighter then 20 ft. lbs or they will break. If you break one call Goodridge they'll send them for free. Be sure to use the new washers that are provided.
hrm.... the first time i was trying to install the lines, i had a problem trying to removie teh stock brakelines from the hardline.... any tips for that? thanks
They DO strip easily, once i noticed i stopped. I think it was 10mm, but what are the Flare Nut Wrenches used for? Those fittings were NOT goin anywhere...
Buy a set of flair nut wrenches.
Definately do this! I stripped the first hardline to hoseline connector trying to use a normal wrench. deifnately get the flare wrenches, big big big help; makes the job real easy.
mortificationrock
14
Aug 1, 2010 05:21 PM
opto_isolator
Jan 22, 2004 10:03 AM
