wont engage into 1st
Old Sep 24, 2011 | 06:47 AM
accordmatt's Avatar
Default wont engage into 1st
just got back from new orleans on work for 2 weeks, cranked her up n let warm up then drove down road smelled gas pulled over had leak on both ends of hose. cut each end and connected back up fixed. then seems like soon as i did that fixed idle issue. then i cant engage into 1st gear. can go into all other but 1st. when car is off i can engage it into 1st. but when running i cant, i let off clutch n hear gears grinding. when i try to shift to 1st its not going in , its like theres no stopping point for it to catch. wtf have any clue whats going on?
Old Sep 24, 2011 | 07:01 AM
Steve Z's Avatar
Default Re: wont engage into 1st
Weird? Maybe the linkage is kinked or you have something loose like motor/tranny mount that's cauing the linkage to act that way when the motors running?
Old Sep 24, 2011 | 07:44 AM
accordmatt's Avatar
ive found no kinks the cables are the same as they have been.
Old Sep 24, 2011 | 09:19 AM
accordmatt's Avatar
i posted this on another forum and there saying tranny is going and need to rebuild. but l havent even been driving it at akk past 2 weeks and l havent been beating on it. someone plz help and tell me its something else
Old Sep 24, 2011 | 11:43 AM
accordmatt's Avatar
think this is issue take alot of force to move this selector cuz the case is cracked and pin is binding up
Old Sep 26, 2011 | 06:50 PM
accordmatt's Avatar
now ive ordered new shift lever cover and springs and etc now should this fix issue or does anyone think maybe synchros in tranny going bad?
Old Sep 26, 2011 | 08:49 PM
holmesnmanny's Avatar
I think it takes a lil while for synchros to go bad even if you race it hard. Hopefully it just got suck in a bad spot and wouldn't budge. If they're bad you'd have to pull it anyhow so just see how it runs when you fix it first.
Old Sep 27, 2011 | 06:26 AM
Steve Z's Avatar
What you described happening is not syncro's. Even if they were bad, you could still get the trans into 1st gear. You'd have to double clutch it or be stopped but it would still go into gear. What you are saying is that it will not go in. That is a linkage issue and if not, you have an internal problem with the shifting fork for that gear.
CD5 Jeebies!
Aug 13, 2007 02:05 PM
spun Vtec
18
Mar 21, 2005 11:00 AM
Taikonaut
Dec 15, 2003 04:37 PM
I Have an STD
Oct 7, 2003 07:02 AM
FOrSfEd
Nov 1, 2002 05:38 AM
