Installing AEM short intake
Old Sep 24, 2011 | 06:26 AM
johnkilo3's Avatar
Default Installing AEM short intake
I'm going to install a AEM short intake on my 99 GSR. My question is, how much of a pain in the *** is it to replace the coolant line that runs directly underneath the throttle body and under the breather hose? That looks to be the most daunting part of the install...
Old Sep 24, 2011 | 06:32 AM
Local's Avatar
Default Re: Installing AEM short intake
Is that required for install??
Old Sep 24, 2011 | 06:33 AM
johnkilo3's Avatar
Yeah, the coolant and breather lines are one piece that can't be seperated, so both need to be replaced with the supplied hoses, at least that's what the directions say.
Old Sep 24, 2011 | 06:42 AM
Local's Avatar
Hmm I've always just left mine & run a tube from intake to valve cover. Of course, it would look cleaner taking the metal pieces out and using the supplied tubes.
Quick google search gave this: https://honda-tech.com/forums/showthread.php?p=337645
CAI but same process for the most part
Old Sep 24, 2011 | 06:50 AM
johnkilo3's Avatar
Thanks, I'll go outside and stare at it and brainstorm for awhile ;-)
Old Sep 24, 2011 | 10:54 PM
JDM_JUNKIE_DA's Avatar
waste of thread
Old Sep 25, 2011 | 09:09 PM
johnkilo3's Avatar
Originally Posted by JDM_JUNKIE_DA
waste of thread
Waste of post.
Old Sep 25, 2011 | 11:36 PM
xjdmpatrick's Avatar
I second this.
Old Sep 26, 2011 | 08:29 PM
NemesisCBR's Avatar
Use a tube to connect the valve cover to the intake and leave the rest alone. Mine is just connected to the other line and sits doing nothing.
Old Sep 26, 2011 | 10:59 PM
johnkilo3's Avatar
I ended up replacing the coolant hose, it was a huge pain in the *** especially with the way the GSR intake manifold turns downwards and the clips were pointing away from me. Ended up having to cut it off. In the end it does look cleaner though.
Old Sep 26, 2011 | 11:53 PM
TOO MUCH TORQUE's Avatar
i have a seperate line for intake to valve cover and for coolant lines. those hard lines are disgusting looking....i got rid of mine
ginlv888
Feb 20, 2005 06:19 PM
ginlv888
Feb 16, 2005 07:40 AM
sombasol
29
Jun 26, 2003 07:45 AM
ScubaStevo80
Apr 12, 2003 08:15 AM
Starrman85
Dec 17, 2002 08:45 PM
