Brakes wont pump out fluid !!
Old Sep 22, 2011 | 06:01 PM
aemintgsr's Avatar
Default Brakes wont pump out fluid !!
Okay so after a year passed by from my car being the body shop I'm in the process of putting my Integra together.I put all my brakes on and it only pumps out fluid from two wheels (driver front, passenger rear)
History: New RS master cylinder, all new stainless lines, 40/40 prop. valve
Old Sep 22, 2011 | 06:39 PM
racebum's Avatar
Default Re: Brakes wont pump out fluid !!
likely a problem with the prop valve. pull the lines and have someone pump, check fluid output directly
Old Sep 22, 2011 | 08:54 PM
aemintgsr's Avatar
Okay no fluid pumped out when I removed the lines from the prop valve...so I guess I'm going to buy a new one
Old Sep 22, 2011 | 08:58 PM
Fliptard's Avatar
is fluid coming from the lines BEFORE the prop? if so, it's the prop, if not.. it's the MC
Old Sep 23, 2011 | 05:20 AM
aemintgsr's Avatar
I don't know I'm assuming it is because it pumps fluid to two wheels only...but ill check if it pumps fluid out of those two lines before it reaches the prop valve
Old Sep 23, 2011 | 08:12 AM
juba_x's Avatar
did u bench bleed the mc?
Old Sep 23, 2011 | 08:23 AM
aemintgsr's Avatar
1 yr ago yeah :p
Old Sep 23, 2011 | 04:41 PM
TheRealTegger's Avatar
Driver front and passenger rear involve the REAR half of the master cylinder. That circuit seems to have been bled of air.
I think you've just got a lot of air still left in the other circuit. Keep bleeding the driver's rear and passenger front.
Are you using the pedal-pump method or a Mity-Vac?
Old Sep 23, 2011 | 04:46 PM
lzyga09's Avatar
mity vac is goood
Old Sep 24, 2011 | 08:19 AM
aemintgsr's Avatar
The pedal pump...I've been pumping for days...when I unpluged the lines from the mc prop. valve only the rear line was pumping out fluid, so Ima bench bleed it...but could it also be the prop. valve?
Old Sep 24, 2011 | 03:32 PM
panama's Avatar
I changed out mine had similar problem.
Old Sep 25, 2011 | 02:35 PM
el crapitan's Avatar
try bleeding at the MC-in vehicle
it's the highest point of the system, so air gets trapped there easily
Old Sep 27, 2012 | 09:33 PM
Blacktie's Avatar
Bump since i dont feel like making a new thread
i recently Deleted my ABS bought new hardlines and a master cylinder and SS brake lines i bench bled the master before i put it on and.. now im only getting fluid out of my Right rear caliper...my 40/40 prop valve was working fine before too
still too much air in the system? somethings broken? any ideas?
Old Sep 28, 2012 | 04:01 AM
usually if i replace calipers or lines, i like to gravity bleed. that is, crack the bleeders and let the air purge on it's own.
also, if the master cylinder is replaced, you want to bleed there, since it's high up in the system and air is easily trapped there
douglaslovin
Apr 28, 2009 06:12 AM
black0hatch
Jan 22, 2008 05:08 PM
vince37
Aug 8, 2006 06:16 PM
93CamaroLT1
Jun 20, 2006 06:48 PM
detaude
Honda Motorcycles
May 18, 2005 03:46 PM
