Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
wheel size for autocross
Old Oct 4, 2002 | 05:11 PM
tygsr's Avatar
Default wheel size for autocross
Is a 17x7 better than a 16 or 15?? Did a search not much info..
Old Oct 4, 2002 | 06:45 PM
fsp31's Avatar
Default Re: wheel size for autocross (tygsr)
For what type of car? Your sig has "gsr" in it. Is it for a GSR? What class? If you're in stock or STS, 15 is preferrable (or required). If you're in SP or SM, 13" is the way to go (these days...). 16 and 17 is too big and heavy, as well as giving the car higher gear ratios.
Old Oct 5, 2002 | 02:23 PM
tmg's Avatar
tmg
17" may be too large for autox but for road racing, depending on the car's power, can be greatly beneficial. light weight is the key for any wheel and 16's can prove best in both racing events, matched with light weight and perfect tires. traction is increased with wider tires, perfect for cornering.
Old Oct 6, 2002 | 04:43 PM
tygsr's Avatar
Default Re: wheel size for autocross (themi6group)
That is what I thought. Wouldnt a wider wheel base be better in autocross? I think I will stick with some light weight 16"s. Considering this car is a street/drag/autocross car I think 16 would be the way to go. This is a turbo gsr, would the wider wheel base help put that power to the ground on corners better??
Old Oct 6, 2002 | 05:38 PM
tmg's Avatar
tmg
definitely the wider the better for an increased contact patch. pulling g's are also increased with a wider track. if you can go 215 for your tires go for it. 205 may be your limit in width.
Old Oct 7, 2002 | 05:12 AM
Audi RS4's Avatar
Lover
i believe 215 is the largest you can go on a teg... some kumho V700 are perfect for AutoXing if you can't afford full slicks and another set of wheels.
Old Oct 7, 2002 | 05:19 AM
PseudoRealityX's Avatar
Default Re: wheel size for autocross (fsp31)
For what type of car? Your sig has "gsr" in it. Is it for a GSR? What class? If you're in stock or STS, 15 is preferrable (or required). 16 and 17 is too big and heavy, as well as giving the car higher gear ratios.
5th place in STS this year in Kansas was a Subaru 2.5 RS running 17s with 225 Falkens. He was .001 out of 4th, behind Richard West. Given the short gears on the RS, the extra gearing probably didnt hurt him too bad, IMHO.
[Modified by PseudoRealityX, 2:20 PM 10/7/2002]
Old Oct 7, 2002 | 05:47 AM
fsp31's Avatar
Default Re: wheel size for autocross (PseudoRealityX)
>>5th place in STS this year in Kansas was a Subaru 2.5 RS running 17s with 225 Falkens. He was .001 out of 4th, behind Richard West. Given the short gears on the RS, the extra gearing probably didnt hurt him too bad, IMHO.<<
That's right, but this is a Honda forum. My guess is, the guy that started this thread probably drives a Honda/Acura. How many 16" wheel clad Hondas were in the trophy's at Topeka? (none in STS, i was there...) In any class? What works on a Subaru has very little to do with what works on a Honda.
Old Oct 7, 2002 | 07:30 AM
Watkinsm3's Avatar
Yeah... a subaru has a little bit more toque then our little hondas!!! they'll have a easier time getting those big wheels to move.
Old Oct 7, 2002 | 07:46 AM
tmg's Avatar
tmg
Default Re: wheel size for autocross (Watkinsm3)
since when did 16" wheels become big? 16's prolly the most versatile.
Old Oct 7, 2002 | 08:16 AM
.RJ's Avatar
.RJ
15" is still lighter, for STS.... 13" for SM and SP.....
Old Oct 7, 2002 | 08:30 AM
tmg's Avatar
tmg
Default Re: wheel size for autocross (.RJ)
i used to race sm with 16"s. i was running a turbo though so that extra tiny weight did me no harm.
Old Oct 7, 2002 | 08:34 AM
577HondaPrelude's Avatar
best rim for autocross is the smallest diameter rim that will fight over your breaks, and the wides width U can fit, and stay in your class.
16x7.5 with 225's fit just fine on my car...
Old Oct 7, 2002 | 09:01 AM
tmg's Avatar
tmg
Default Re: wheel size for autocross (57STS)
agree. the worst thing with going with small diameter wheels are that the tires are generally tall tires to make up for the size loss. with tall 60 series tires, they don't have a good solid tire wall. unless you have multi sets of tires i.e. 45's for autox and 55 for street.
Old Oct 7, 2002 | 11:26 AM
don't get taller tires, who give a crap if your speedo is off a bit... also smaller overall diameter = geard for acceleration
small diameter wide width tires, and small diameter rims with wide width best way to go
[Modified by 57STS, 3:27 PM 10/7/2002]
Old Oct 7, 2002 | 12:01 PM
tmg's Avatar
tmg
diameter is important because it can negatively alter the geared transmission's key points for particular power on the rpm band.
Old Oct 7, 2002 | 12:27 PM
Crack Monkey's Avatar
For a multi-use car and only one set of wheels/tires, a set of lightweight 15x7" with sticky summer tires will be your best bet. From what I've seen, 15" has good tire availability at reasonable prices. The 16+ sizes (for wheels and tires) tend to be more expensive, much heavier, and of limited availability in decent Honda sizes.
If you are looking for wheels for autox only, then 13x7-9" with R compounds is a good bet. Be careful choosing 13" wheels - only a few brands will clear GSR calipers.
Old Oct 7, 2002 | 01:19 PM
tygsr's Avatar
Default Re: wheel size for autocross (Crack Monkey)
Considering this car is a street/strip/scca car I am not going to buy tires just for SCCA. I think a 16" wheel with a 215 azenis will work great...the 16" weighs only 13 lbs and the car is turbo so the extra weight wont hurt too much..
Old Oct 7, 2002 | 01:25 PM
typer_801's Avatar
The STX National Champ (in an ITR) was running on 16" Buddy Club's with 215/45/16 Azenis. It may not have been ideal, but it worked
[Modified by typer_801, 5:27 PM 10/7/2002]
Old Oct 7, 2002 | 01:36 PM
RineRacing's Avatar
If the car was truly all three things then you would have at least 3 stes of wheels. If you're looking one rim for all three then you will only be mediocre at best at whatever you do.
Old Oct 7, 2002 | 01:43 PM
tygsr's Avatar
Default Re: wheel size for autocross (Geratol)
I am buying slicks for drag, and since I will be only autocrossing a few times a month I think my setup will work fine.
Old Oct 7, 2002 | 01:47 PM
Namlak's Avatar
Matt Guiver (2nd place STS at the Wendover ProSolo) was running 225's (712's, I think) on his 4-door 'teg last year but I think he now runs 215/45-16 Azenis now. So with careful fitment, you *can* get 225's to fit.
I think for a combo street/autocross, go with the 215/45-16 Azenis on 7 or 7.5" wheels (don't go narrow on wheels).
Old Oct 7, 2002 | 07:07 PM
fsp31's Avatar
Default Re: wheel size for autocross (typer_801)
>>The STX National Champ (in an ITR) was running on 16" Buddy Club's with 215/45/16 Azenis. It may not have been ideal, but it worked<<
brain said "17", fingers typed "16".
Jeff, quit being so stinkin humble! You're allowed to say "I was running on 16" Buddy Club's". Congrats again on the win! BTW, I worked the corner with you on the south course...
Old Oct 7, 2002 | 07:23 PM
Todd00's Avatar
I said I don't want a title!
Yes, and the second place STX driver was on 15" SSRs with 205/50/15 Azenis (which are, pretty much, identical in width to the 215/45/16 Azenis).
The ideal size is probably a 225/45/15 Azenis, which of course is not made...
94jdmlude
Dec 3, 2008 11:45 AM
TheMidasTouch
Aug 19, 2008 07:55 PM
nonvtecD
14
Apr 22, 2004 09:55 AM
non-VTEC
Mar 17, 2002 09:24 PM
70WHP LOL
Jun 15, 2001 10:35 AM
