92 Civic DX HBbest spark plug wireset
as above, car shakes on idle, I am hoping replacing the plugs, and the wireset will fix this, otherwise I'll have to check the ignition timing. So since I bought 9 dollar a piece plugs, I want to get a wireset that is just as good.
Cost does not dictate your plugs are good or even suitable for a Civic. Good old NGKs are enough with Sumitomo wires.
What plugs did you get?
Overkill and overpaid.
As for the shaking you already posted that here.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-civic-dx-hb-shaking-2977202/
Should have just continued on that thread.
if you can return those plugs, and just get a basic set of NGK plugs. All those platnum things do is last longer, there is no benefit other than that.
As for wires, what marc said, or OEM. Also, do ignition timing at the same as plug/wires, also, looking to swapping the cap/rotor. OEM in this area also.
Any cel's? Shaking could be caused by a missfire, but, you'd have a CEL.
