93 del sol with D16Z6 -- timing/power issues HELP PLEASE!!
Old Sep 21, 2011 | 11:53 AM
frostdragon1's Avatar
Icon6 93 del sol with D16Z6 -- timing/power issues HELP PLEASE!!
im going to try the boards one more time to see if i can get some help. i rebuilt my d16y6 1.6 vtec top to bottem new everything almost and for some reason im having horrible issues trying to get the timing and power back. when i timed it tdc the disturbitor had to be ajusted all the way forward for startup and idle. when you give it gas under a load it bogs and missfires really bad and has no acceloration. i tryied re-timing 3 times one a tooth to the exhaust and one a tooth to the intake and it still is having bad issues. i get it to start up fine and the only time a chech engine light came on was one tooth intake. i have no audiable, visual leaks fluid or vaccume, i already cleaned out the whole throttle body and every valve/ sensor. im stumped and fursterated all help is welcomed and would like to resolve this issues asap so i can have my dd back. thank you all and thank you Ron in advance for help.
Old Sep 21, 2011 | 01:32 PM
Former User's Avatar
Default Re: 93 del sol timing/ power issues HELP PLEASE!!
Completely stock D16Z6? OEM timing belt?
Turn the crank pulley several full revolutions counterclockwise just until the cam is set perfectly at TDC1. Take crystal clear pictures of the cam alignment and the crank pulley TDC1 mark alignment with the pointer on the lower timing belt cover.
Old Sep 21, 2011 | 07:35 PM
Default Re: 93 del sol with D16Z6 -- timing/power issues HELP PLEASE!!
will do a retiming on friday as i dont have school then. thats the exact same guide i used from alldata from honda. but i will try again and take pics for you and a post test drive follow up. thanks for your time and help
Old Sep 21, 2011 | 07:38 PM
used the same guide, but i will re time on friday with pics. only has a short ram intake.
shady3260
Jun 8, 2010 12:21 PM
tundra2000
Feb 6, 2010 01:50 PM
alchem
May 27, 2007 12:52 PM
PatrickGSR94
14
Oct 7, 2006 07:52 PM
civicex_88005
16
Jul 8, 2005 06:02 PM
