OBD0 to OBD1 jumper harness questions
Old Sep 21, 2011 | 08:22 AM
honda dan's Avatar
Default OBD0 to OBD1 jumper harness questions
hey guys i bought a jumper harness off ebay to help in my d16z6 swap and im having some doubts in the wiring
Heres a link to the harness i purchased
http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
just wondering if anybody has used this or knows of a wiring diagram to help me out. i have all the wires hooked up according to a rywire schematic and the only issues im having is i have 2 black wires (one of which im lead to beleive runs vtec) and a red wire and a pink wire -which id like to run to the 2 extra wires off the new distributor ................any help would be uh helpful ...im in the process of contacting the manufaturer now so hopefully i can get this fired up by the weekend! -thanks in advance
Old Sep 21, 2011 | 09:36 AM
honda dan's Avatar
Default Re: OBD0 to OBD1 jumper harness questions
bump before work feels like i should just order the Rywire harness n save myself the hassel -__- idk
Old Sep 21, 2011 | 11:41 PM
honda dan's Avatar
damn
Old Sep 22, 2011 | 08:14 AM
honda dan's Avatar
bump before work again
Old Sep 23, 2011 | 09:44 AM
honda dan's Avatar
alotta wrong **** with this harness guess im just gunna snipp n start over
Old Sep 24, 2011 | 04:37 PM
Bently_Coop's Avatar
Steve at Heart
I purchased the full Rywire kit and it looks good. Its all plug and play.
Old Sep 24, 2011 | 11:02 PM
honda dan's Avatar
really wish i woulda bout the rywire kit deff a must for the next swap ...anyway i just re wired most of the harness but im stuck with the injectors and the distributor ....im thinking i can run the blue/yellow and blue/green straight to the ecu i think its like pins B14 n 15? could be wrong tho. does this sound right to anyone? also i have the injectors all set up with the red and yellow wires extrended in by my ecu again i should just be able to jump into the right wires yea? just not positive on the pins i saw a guy saying to take C1 and C2 but im thinking that they need to be in A1 and A5. i searched but found mixed reviews on both so im looking just for a straight answer if anyone knows. i just want this thing running lol
Old Sep 25, 2011 | 06:56 AM
honda dan's Avatar
buuumnmmmpppp anybody do this?
Old Sep 25, 2011 | 08:35 AM
honda dan's Avatar
bummmmmmp ttt anybody??
Old Sep 25, 2011 | 10:07 AM
honda dan's Avatar
all i got is 4 wires left anybody help me here? so close!! lol
Old Oct 15, 2011 | 07:50 AM
honda dan's Avatar
alright i got everything goin just wasent getting fuel ...i installed a fuel pressure gauge n it says its getting around 40psi ... im feeling like i need a map sensor now anybody wanna 2nd that or lead me in any other direction? any help is helpful
Old Oct 15, 2011 | 09:49 AM
honda dan's Avatar
bump before work
Old Oct 15, 2011 | 07:35 PM
honda dan's Avatar
ugh bump after work
Old Oct 15, 2011 | 08:56 PM
honda dan's Avatar
juss lookin for a second opinion ...bump
Old Oct 15, 2011 | 09:06 PM
honda dan's Avatar
juss want a 2nd opinion ...from anybody lol buying it tm i guess
Old Oct 16, 2011 | 07:39 AM
honda dan's Avatar
morning bump............
Old Oct 16, 2011 | 09:12 PM
honda dan's Avatar
map sensor??????????????
Old Oct 17, 2011 | 08:01 AM
honda dan's Avatar
lunch bump ....................
Old Oct 17, 2011 | 07:36 PM
honda dan's Avatar
after work bump
Old Oct 18, 2011 | 07:19 AM
honda dan's Avatar
bump tttttt
Old Oct 18, 2011 | 07:24 PM
honda dan's Avatar
any body got a second opinion on this?? ...bump
Old Oct 19, 2011 | 09:44 AM
honda dan's Avatar
bump before work ..........any body got any ideas if this dosent work??
Old Oct 20, 2011 | 09:19 AM
honda dan's Avatar
map sensor didnt do it -__- i had my brother watch the fuel pressure gauge and he said it drops from 40 psi down to 30 when im cranking
Old Oct 20, 2011 | 07:38 PM
Relic1's Avatar
which wires do you have left and where do they connect to the ECU?
pin definitions --> b18c5eg.com/obd1.jpg
Old Oct 20, 2011 | 08:41 PM
honda dan's Avatar
i got all the wires in and pluged in and right...i believe but now im not getting fuel i guess. i have a fuel pressure sensor right off the filter an says im getting 40 psi i just had my brother watch it while i was cranking tho an he says it drops to about 30 but only while cranking. im thinking thats normal from the power drain while cranking tho. i might have the tps n map sensors switched around tho so ima mess with those now i have to switch the outside wires on the tps for the mpfi swap yes?? idk i took a break from it n am coming back to it to start playing with some stuff again
