Problem with Crower valvetrain
Old Sep 21, 2011 | 12:44 AM
pentaq's Avatar
Icon6 Problem with Crower valvetrain
Hi,
I've a problem with Crower springs and retainers in the H22A7 (TypeS) head. Actually nothing is wrong with springs as the compress enough to lock them in place. The problem are retainers. I can't set a proper valve lash in 10-11 valves. After the inspection it appeared that the rocker arm was hitting/lean against the retainer before the adjusting screw even approached the valve.
Did anyone experience such a problem? What to do with that?
Old Sep 21, 2011 | 03:08 AM
bluedlude's Avatar
Default Re: Problem with Crower valvetrain
That has been a well documented problem with the crower valvetrain from day 1. It's not your fault man. Most people just make a relief in the rocker arms to clear the retainer.
Old Sep 21, 2011 | 06:28 AM
pentaq's Avatar
Where can I find more info on this? Thanks a lot.
Edit: nvm I found it. Anyway thanks again for enlightment. I don't like the grinding rocker arms idea. We're going back to OE retainers and stiffer springs.
Old Sep 21, 2011 | 04:34 PM
NirVTEC's Avatar
Good ole Crower! YeeHAaa!!!
vtec dub
Aug 9, 2007 08:54 PM
misterpsycho
Apr 2, 2007 12:48 PM
Black R
Jun 5, 2005 01:06 AM
vtecvoodoo
10
Oct 23, 2003 09:48 AM
austrian type-R
Jun 27, 2003 07:25 AM
