questions for the pre 98 non abs ITR owners
Old Sep 20, 2011 | 09:34 PM
HmgLauj69's Avatar
Default questions for the pre 98 non abs ITR owners
specific questions for the non abs ITR owners, having a hard time digging up the info.
what size is your stock brake master cylinder(bmc)?
are there lines coming out both or just one side of the bmc?
what type proportioning valve do you have (see pics)?
can you take a picture of your bmc and proportioning valve?
Old Sep 21, 2011 | 06:28 AM
Dave-ROR's Avatar
Default Re: questions for the pre 98 non abs ITR owners
All USDM ITRs had ABS.
To convert to non ABS you need the 4040 prop valve on the right, some Integra RS lines (prop valve to front right wheelwell, prop valve to front left wheelwell, prop valve to MCx2). You reuse the ABS BMC or change to the RS and RS booster, which is not worth doing at all. You will have to cut one new brake line and one old one to convert.
Oh, and this info is easily found searching google BTW
Old Sep 21, 2011 | 07:24 AM
HmgLauj69's Avatar
Are you sure? I thought, pre 98, Abs was optional.
Old Sep 21, 2011 | 08:08 AM
exies's Avatar
Yes, all USDM ITR came with ABS.
Other then the RS trim, all Integra's had ABS.
1998-2001 Integra's including the 1997 ITR got the slimmer ABS module.
Old Sep 21, 2011 | 09:23 AM
Tyrant_007's Avatar
You might be thinking A/C instead of ABS...Optional in 97 & 98...
Old Sep 21, 2011 | 10:18 AM
HmgLauj69's Avatar
I'm pretty sure Abs was optional; not sure if this is true for only non usdm though.
Old Sep 21, 2011 | 10:27 AM
Spunkster's Avatar
ABS was on all us ITRs. IT was not an option.
Removing the ABS is a bad idea even for a track car, you can improve lap times bay having ABS
Old Sep 21, 2011 | 10:41 AM
HmgLauj69's Avatar
Looks to be the case, can't find any information that says other wise. Guess I was wrong
Old Sep 21, 2011 | 01:02 PM
Dave-ROR's Avatar
It's not a bad idea at all for a race car. For a casual DE car I'd agree but you do NOT want a race car rolling back across the track thanks to ABS. That's why many sanctioning bodies (including SCCA) require it's removal.
Old Sep 21, 2011 | 01:03 PM
Dave-ROR's Avatar
For USDM you were definately wrong. I've never seen a JDM ITR without it either but it could exist.
Old Sep 21, 2011 | 01:25 PM
teg97's Avatar
my old jdm R had no abs and I have pics to prove it
Old Sep 21, 2011 | 02:29 PM
Klasse's Avatar
Yeah a few JDM ITRs didn't have ABS. OP: I can take a pic of bmc and prop valve if you still need it? '96 spec with factory no ABS, not sure if that will help you?
Old Sep 22, 2011 | 02:57 PM
Dave-ROR's Avatar
Cool. Always good to learn new stuff. I'm not into the whole JDM thing so I never bothered to learn that info
trm4life
Apr 27, 2017 05:28 AM
ZCHondaCRX91
Suspension & Brakes
Feb 4, 2012 09:18 PM
GSR-TRBO-DA
Sep 16, 2007 06:32 PM
nikolai.
Jan 12, 2007 11:08 PM
