92 civic hatchback with f22 swap wont start (fuel)
So basically I have a 92 civic hatchback with a f22 out of an accord in it. It worked fine but then I pulled the engine out to replace the tranny and now that ive put it back in it wont start. As far as I can see all the clips and wires are connected. I think its a fuel issue because it starts with starter fluid but my fuel pump is fine and it pumps fuel to the injectors but after that I have no idea if fuel is even getting to the engine (so i think it is something electronic too).
Let me know if anyone has any ideas... Thanks
pull the injectors and have someone hold it and pint it down so they dont spray them selves and see if the injectors are spraying when u crank the motor over. do you hear the fuel pump prime? if not check your fuses inside out under the engine bay(unless relocated) make sure they are all good.
Ok i checked the injectors. the fuel pump is fine there is fuel to the rails but none past the injectors, there doesnt seem to be any codes. I did find a clip that was disconnected but it has nothing else to plug in to so. Im going to post a picture of it to see if anyone can identify it or anything but otherwise let me know if you have any ideas.
ok 92lxsleeper was right i didnt have the part that connected to that it was up on a shelf lol
It runs now so thanks everyone
b16a1eg6
26
Feb 19, 2011 02:42 PM
corked1260
14
Jan 28, 2008 03:13 PM
