97 civic/LS swap -- idles high, surges, and throws code P1508
Old Sep 20, 2011 | 12:59 PM
jdmdreamz414's Avatar
Icon3 97 civic/LS swap -- idles high, surges, and throws code P1508
I have a problem code 1508 iacv malfunction..replaced iacv did idle relearn procdure and my car still idles high like 2k it starts off at 1500 then creeps to 2k bled coolant checked for vaccum leaks nothing..grey messing with the idle screw Nada..idk wut else to do my car is a 97 ek with a ls swap..I'm guessing the guy used a single cam harnesses cause he did the 3 wire iacv conversion..please can u point me in. The right direction..my idle surges up nd down nd if I unplug the iacv it stablizes.. please help I also checked the tps.. and I'm running and ls ecu..I also want to run the tps wires straight to the ecu how do I go about doing that..thank you very much for your help..
any input helps please..
Old Sep 20, 2011 | 06:47 PM
Default Re: civic idles high,surges
Anybody??
Old Sep 20, 2011 | 07:05 PM
Former User's Avatar
Unplug ECU connector A and check whether the Blu/Blk wire at A14 has been moved to A12. Also, has the Orn wire at A13 been disconnected?
Old Sep 21, 2011 | 01:06 PM
Default Re: 97 civic/LS swap -- idles high, surges, and throws code P1508
This has been done as far the Orange wire on the ecu side .its still there but .up in the engine bay its just laying there
Old Sep 21, 2011 | 01:07 PM
So yes it has Ben disconnected to answer ur question
Old Sep 21, 2011 | 01:19 PM
That's half an answer. What about the Blu/Blk wire?
Old Sep 23, 2011 | 08:14 PM
the blue and black wire is connected to one of the wires on the iac plug
Old Sep 28, 2011 | 10:11 AM
Anybody???????
Old Sep 28, 2011 | 10:14 AM
Stop and pay attention. Check ECU connector A and make sure the Blu/Blk wire has been repinned to A12. Don't bump the thread until you have checked this.
Post pictures of the ECU and IACV connectors.
Old Sep 30, 2011 | 08:49 AM
Ron it is repined to a12 the car idled fine..then all of a sudden it started to do the idle hunting even after I changed the iacv..
Old Oct 3, 2011 | 08:14 AM
Old Nov 10, 2011 | 08:47 AM
Anybody..the blue/blk wire is connected as well..I checked the wire with a dmm..nd got 12v on that wire and 10v on the other..so I just ran a wire st8 to ecu pin a12 and did the whole relearn procedure..and nothing can somebody Plzz help me..when I disconnect the iacv the idle stablizes..but when I keep that plugged in and disconnect the tps car runs fine just Damn high idle!!! Plzzzzz help
Old Nov 11, 2011 | 07:19 AM
Anybody????
Old Nov 11, 2011 | 07:27 AM
Post a picture like that shown in post #3 showing the rear of ECU connector A.
Old Nov 11, 2011 | 01:44 PM
file:///C:/Users/Dad/Desktop/pic%20offile:///C:/Users/Dad/Downloads/IMAG0146.jpg%20harness.htm
Old Nov 11, 2011 | 01:46 PM
Picture doesn't display. Upload pictures to PhotoBucket and then copy and paste the IMG codes into your post.
Old Nov 11, 2011 | 04:50 PM
Click on the uploaded picture and copy the IMG code:
It should look something like this:
(* = G)
[IM*]http://i639.photobucket.com/albums/uu115/RonJ_HT/Honda%20Civic/picture_6424.jpg[/IM*]
Then paste the code into your post.
Old Nov 14, 2011 | 05:01 AM
Old Nov 14, 2011 | 05:02 AM
Sorry i am new to Photobucket..the wire u see is going straight to the first wire on the iacv connector..
Old Nov 14, 2011 | 05:44 AM
Wrona's Avatar
Gosh that wiring is a mess you should get some heatshrink from harborfreight as well as a soldering iron for 4 dollars and than get some solder for 5 bucks from radioshack and get rid of that shitty wiring
Old Nov 14, 2011 | 06:32 AM
Yes I kno that's next on my list going to pull the whole harnesses out and re do everything..just been busy at work
Old Nov 14, 2011 | 04:17 PM
Ok just re did my wires and still nothing!!! Ughh I give up guys I dnt know what else it could be..any sugestions!!!
Old Nov 14, 2011 | 04:27 PM
Why is an extra black wire spliced to the Blu/Blk wire at A12?
Old Nov 14, 2011 | 04:40 PM
Becuase i was getting 10v on that wire so I ran that black wire to a12 and still got 10v..I got 12v.on the other wire
Old Nov 14, 2011 | 04:51 PM
I have no idea what you are saying. Where does the black wire go to and why is it spliced into the Blu/Blk wire? A12 should only be pinned to the Blu/Blk wire.
