My all motor gsr setup. Good numbers?
Old Sep 19, 2011 | 12:58 PM
travishoward's Avatar
Default My all motor gsr setup. Good numbers?
94 gsr.
B18c1.
Port matched 1st gen s2 mani.
Thermal gasket.
Blox 68mm tb.
Cm Lightweight flywheel.
Usdm 2000+ itr cams.
Stock block and head (other than the cams)
Obx tri-y longtube header with 3" straight pipe with turndown.
Walbro 255.
nology sparkplug wires.
Stock 240cc injectors.
Tuned on crome with a p28.
Itr tranny.
Carbon coated synchrotech synchros.
Quaife LSD.
Gator axles.
Full energy suspension bushing kit.
Innovative mounts.
Avid torque mounts.
No name traction bar.
Made 186whp and 132wtq.
Are these good numbers?
I plan on running the 13.5 class in October, think it's possible?
Old Sep 19, 2011 | 01:18 PM
Default Re: My all motor gsr setup. Good numbers?
Old Sep 19, 2011 | 01:34 PM
Builda'Teg_92's Avatar
those #s are pretty darn average.
and its spelled crome
Old Sep 19, 2011 | 01:44 PM
88Hatchy's Avatar
What chassis?
Old Sep 19, 2011 | 02:14 PM
Haha the chassis would help huh.. My bad. It's a 94 si hatch.
And my bad for misspelling a word spelled incorrectly?..
Old Sep 19, 2011 | 02:32 PM
C_Rock77's Avatar
For a stock block/head, IMO, those numbers sound pretty good. It's all relative, considering the variance in dynos.
Old Sep 19, 2011 | 02:37 PM
That's what I was thinking an was told. Had the tune done at proven power in temple terrace Florida
93egSLEEPER's Avatar
That 13.5 class is going to be a bit of a stretch unless you have your launch and everything down pat from the get-go. Should run in that area if you pull decent 60' times. My EJ1 (2550 lbs) w/ GSR build made right at 180whp and runs consistent 13.9's with 2.0 60's.
Old Sep 19, 2011 | 02:39 PM
Oh and the green is what I made before the tune with just a basemap. The blue is after the tune.
Old Sep 19, 2011 | 02:40 PM
That's pretty good IMO. I hope to hit the 13.5 mark. I don't wanna spray
Old Sep 19, 2011 | 02:46 PM
13.5 is VERY attainable if you can drive the car to its full potentail. Any idea what it weighs? Cams would be a nice upgrade, something like tuner 2's
Old Sep 19, 2011 | 03:01 PM
I have a build I plan on doing. 85mm gsr ,stroker. However I want to run the 13.5 with the setup now. I'll be going s2 pro1's with the build. But the itr's should do til then
Old Sep 19, 2011 | 03:17 PM
killakev's Avatar
I have basically the exact setup except a shitty dc header, 3" intake with velocity stack, my skunk 2 Mani isn't port matched, and I have full 3" exhaust/ muffler.. Tuned on Neptune I made 185whp 137tq.. Jdm b16 tranny
Old Sep 19, 2011 | 03:25 PM
That's another thing, I have a 3 inch short ram. I wish I was making that tq haha. I had a dc header but got rid of it for the tri-y. I picked up 20wtq in my midrange
Old Sep 19, 2011 | 03:26 PM
Is your mani the newer proseries mani?
Old Sep 19, 2011 | 03:28 PM
killakev's Avatar
Yea it's the newer version, and also the new gen skunk 2 68mm Tb
Old Sep 19, 2011 | 03:32 PM
That's why then. Mine is only portmatched at the tb. To 68mm
Old Sep 19, 2011 | 09:17 PM
C_Rock77's Avatar
You need to do some more research on cams
Old Sep 19, 2011 | 09:54 PM
jdmcivic2fast's Avatar
i went 13.01 with 183/133 in a 92 vx chasis on 22x8x13's
only thing was taken out was passenger seat and back seats, probably weight around 2200-2300lbs. with me in it.
I think you should run 13.50's no problem if your on slicks.
Old Sep 20, 2011 | 03:37 AM
why is that? im posting in relation to what i have now, this isnt a thread for my upcoming build. i only stated what cams id be going with eventually with a build, and that the itr cams i have now should support a 13.5 class.
Old Sep 20, 2011 | 03:42 AM
that'd be nice, what exactly was your setup?
Old Sep 20, 2011 | 04:44 AM
nus_dogg's Avatar
Nice numbers.
Old Sep 20, 2011 | 05:11 AM
crazydominicanman's Avatar
Sounds right.
Old Sep 20, 2011 | 05:18 AM
wolve's Avatar
not a stretch at all. 193whp (bone stock 96spec B18C) in my EJ1 chassis netted me a 13.3 on streettires (high 2.0 60ft) within 5 tries at the track. 186whp+hatch+streettires= easy 13.5 if you somewhat know how to drive
but on streettires it should also be cake
Old Sep 20, 2011 | 12:52 PM
LSvtec
stock Gsr head
skunk2 satge 2 cams tuner series
skunk2 valve train
skunk intake manifold
stock tb
crappy dc header with 2 1/4 collector
stock injectors
Ls block
b16 pr3 pistons
ls rods and arp rod bolts
this made 183whp and 133tq and ran 13.01 on first run out at the track, then broke a axle on the second run in the burnout box and didnt get to run anymore.
i later put on a ported head, 68mm tb, a ebay tri y header 2.5 collector, and a set of rc 440cc injectors and retuned, dynoed 215whp 143tq. a BIG difference! didnt get a chance to run this and sold the motor to a buddy.
He ran mid 11's with it but it was in a 1700lbs chasis.
