Solid Motor Mounts?
Old Sep 19, 2011 | 06:22 AM
Dontoh's Avatar
Default Solid Motor Mounts?
Tried looking around for some info on these, can't seem to find much.. Does anybody have them in their car? If so, how do you like them, pros cons?
I recently did a b18c head on a b20b block and my car has terrible wheel hop 1st-3rd. A bunch of my buddies are telling me to go for the solid mounts, but im worried that it will make the ride extremely uncomfortable. I understand its only a 4 cylinder, so it can't be TOO bad, but I was hoping for some info from someone that actually has them..
Any input?
Old Sep 19, 2011 | 06:25 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Solid Motor Mounts?
Wheel hop? Traction bars.
Old Sep 19, 2011 | 06:26 AM
kaiba's Avatar
Solid mount will make the car vibrate worst then your grandma vibrator.
Old Sep 19, 2011 | 06:31 AM
DELshaneSOL's Avatar
if you mount the motor solid then the tranny also should be mounted solid.if you will be spending time on the street i would advise energy suspension polyurethane mounts, pretty stiff but still has some vibration control.but if ur racing then go solid
Old Sep 19, 2011 | 06:41 AM
Dontoh's Avatar
That's what I was thinking. Buddies seem to know more than me though
Yeah, no good. A friend said its a eg tho, comfortability when out the window 15 years ago
I've heard mixed opinions about this. I've heard the tranny SHOULDN'T be solid, and I've heard that they SHOULD..
My mounts are pretty bad anyway, so instead of going solid, I wanted to just go really stiff.. I feel like things will go wrong if my entire chassis is under vibration all the time
Old Sep 19, 2011 | 06:56 AM
look up hasport mounts they use a pressed aluminum which allows the motors vibrations to be dampened a bit more.
solid mounts your going to be putting more through your tranny which is a good thing...but having poly mounts means that they do absorb what could be potentially harmful initial shocks from your motor which could come from launches etc...so poly will give you an almost solid like driveline, while still keeping your frame safe from all the vibrations.
Old Sep 19, 2011 | 06:59 AM
Dontoh's Avatar
Any hasport mount, specifically?
Old Sep 19, 2011 | 07:09 AM
FlewByU352's Avatar
Solid mounts: great throttle response, unbelievably crisp shifting, and unless it is a dedicated track car you will rattle your brains out and hate driving it. On the street your mirrors are useless, the chassis resonates so loud you have to shut your car off to talk to someone and people think your car is a piece of **** which is a nice theft deterrent lol.
Old Sep 19, 2011 | 07:11 AM
Part Number: EKSTK
when you buy them you could also tell them how stiff you want them
62A (Street)
70A (Race)
88A (Extreme Race)
Old Sep 19, 2011 | 07:18 AM
Dontoh's Avatar
Yeah I gotta agree. Don't get me wrong, I like to think my car is track inspired with the suspension set up, motor work etc.. but it's also my daily, and it has to be practical. It's loud enough with a gutted rear end
Part Number: EKSTK
62A (Street)
70A (Race)
88A (Extreme Race)
I saw that, I'm stuck between 62A and 70A. I feel like street may be too soft, but I'm not sure if race will be too much. Any clue?
Old Sep 19, 2011 | 07:26 AM
really depends on what you drive more, i drive mostly freeway so id probget 70a
Old Sep 19, 2011 | 07:47 AM
HellaFab's Avatar
They are all hard and will all have minimal deflection. just get the 62A
Old Sep 19, 2011 | 08:45 AM
Moonraker09's Avatar
What do you base yourself on ?
Old Sep 19, 2011 | 09:36 AM
phelpsj2's Avatar
i have the 62a on my b16 with my comp clutch stage 2 and the motor doesnt move. shifts are crisp, and most the power gets transfered nicely to the wheels. they have broken in alil and got a tiny bit softer, but not much...still no motor movement what so ever. highly recomend them
Old Sep 19, 2011 | 10:46 AM
Hasport's Avatar
62a any car driven on the street
70a weekend racer or hardcore street driver
88a race car drag/road race
94a dedicated drag car
solid 850 or greater hp drag car
Old Sep 19, 2011 | 03:58 PM
slumdog1's Avatar
I got the diy liquid poly kit off of energy suspension (80A) for 30 bucks for my 94 eg d16z6. turned out real nice, shakes alot at idle and take off, but it doesn't bother me, but while im driving its cool. night and day difference in throttle response/shifting/handling. engine doesnt move at ALL like it used to when i rev it up . i would definitely recommend, cant beat the price.
Old Sep 19, 2011 | 07:49 PM
EsotericImage's Avatar
Retired Moderator
im using these and theyre perfect.. just a little vibration, but nothing that will rattle ur teefs
http://www.velocityshop.com/product/...civic_326.html
Old Sep 19, 2011 | 07:58 PM
FlewByU352's Avatar
I am currently running HASPORT 62a mounts and AVID 60a torque mounts. I am planning on switching to the HASPORT 70a inserts and the AVID 40a torque mounts then running traction bars to get rid of wheel hop. I want to build another track car in the worst way to use solid mounts because once you experience them it is love.
Old Sep 20, 2011 | 06:33 AM
Dontoh's Avatar
What do ya mean?
Awesome, that's what I'm looking for, I also have a stage 2 clutch, love the thing.
The 62a will stop motor movement, correct? I don't consider myself a hardcore street driver, but at the same time, I like the potentiel to be there.
I'm sure I'll be getting in touch with you guys, might just stick with the 62a's.
Originally Posted by EsotericImage
im using these and they're perfect.. just a little vibration, but nothing that will rattle ur teefs
I'll look into those, thanks
Old Sep 20, 2011 | 08:47 AM
HellaFab's Avatar
you want 62a from this description.
compared to stock these are hardcore.
Old Sep 20, 2011 | 04:47 PM
Dontoh's Avatar
perfect
Old Sep 20, 2011 | 05:09 PM
The Grumpiest
I'm running these. No complaints going on 5 years now.
Old Sep 20, 2011 | 07:56 PM
Dontoh's Avatar
they have em for b series in an eg? can't seem to find them.. how are they as far as stiffness goes?
Kaspk
17
Jan 19, 2008 06:54 PM
ImPuLsIvE
Dec 19, 2007 01:23 AM
teddy_dc2
May 2, 2006 10:32 PM
steve96accord
Apr 5, 2006 12:03 AM
SamC
Apr 10, 2002 01:11 PM
