2000 accord brake job
I'm no newb to hondas, but I have never worked on my fiances accord. The factory 100k warranty just expired and I have to do a brake job. I already purchased the pads and rotors, just looking for some info.
Are the rotors pressed on? Any advice or tips would be appreciated
Thanks in advance,
D
had to add these
accord
my prelude
Thanks in advance,
D
had to add these
accord
my prelude
ogsmakdade: it's a pretty straight forward job.
a few tips- it's well worth it to get an impact driver like this...
for removing the rotors. also the rear caliper pistons need to be reset by twisting CW as you press. there is a special tool for this, although i've gotten away with using a large prypar like a screwdriver. not always easy that way
. there's nothing special really about brakes on this model. if you're familiar with brake jobs you'll have no trouble.
I was told that the Acura CL had the same setup as the Accords. They are pressed on also?
OP: here's a diagram of the front brakes.
here's a diagram of the rear brakes.
ogsmakdade the brakes on the Accord are nearly the same as your Preludes.
https://honda-tech.com/forums/honda-accord-1990-2002-2/diy-rotor-over-hub-conversion-2027047/
Nobody likes the FAQ anymore.
Originally Posted by JDM_DC4_FanaticParts:
1998 Acura 2.3CL Front Hubs OEM part # - 44600-YS8-A00
1998 Acura 2.3CL Front Rotors OEM Part # - 45251-S84-A01
1990-1998 Accord Front wheel bearing OEM Part # - 44200-SM1-008
1990-1998 Accord Front brake pads OEM Part # - 45022-SY8-A01
New cotter pins
New cotter pins
rotors are never pressed on. 90-97 Accords have the hub pressed over the rotor. the hub has to be pressed out to replace the rotor. the newer models have the hub behind the rotor so the rotor can simply be removed by undoing the two retaining bolts.
the process was the same as doing a brake job on my prelude. I replaced all four disks with brembo blanks, and used hawk hps pads. Hopefully my girl is happy with the setup.
I should have just jacked the car up and found out for myself but I was pressed for time.
Thanks for all the positive responses guys, very helpful.
this is why I did the work in the first place. crack all the way around the hub.
pretty much split all the way around, it didn't come apart when I took it off though. there was about an inch and a half that wasn't cracked, holding it together.
I always install brand new ones when I did the brakes on my lude. I installed them on all wheels accept the one with the split rotor on the accord. They wouldn't come loose, so I had to drill them out.
https://honda-tech.com/forums/showthread.php?t=2027047
However, I always wonder if maybe if you grease them good with brake grease before putting them on would guarantee them coming off later. Also, one thing I have also thought about is that perhaps they might help keep the rotor on straight as it's spinning real fast at high speeds even though the brake pads do keep it on straight. Just a little venting here.
That's why I leave them off.
on the other hand though there's no shifting around of the rotor when the wheels are rotated if the bolts are used. they keep everything tidy and secure.
You talking about the spray stuff ? I use that on the back of my pads. I spray, let it dry, spray, let it dry until I have a few coats of it.
If you're talking about grease, you need high temp brake grease since cv axle grease will burn off faster.
creator1322
17
Jan 30, 2008 03:39 PM
