2000 accord brake job
I'm no newb to hondas, but I have never worked on my fiances accord. The factory 100k warranty just expired and I have to do a brake job. I already purchased the pads and rotors, just looking for some info.
Are the rotors pressed on? Any advice or tips would be appreciated Thanks in advance, D had to add these =) accord http://i113.photobucket.com/albums/n...e/DSCF0261.jpg my prelude http://i113.photobucket.com/albums/n...g?t=1271532197 |
Re: 2000 accord brake job
Not sure, but I'm assuming the front rotors are pressed in. Not sure if Honda went with a different setup in the newer accords.
Originally Posted by 75aces
(Post 46040994)
ogsmakdade: it's a pretty straight forward job. a few tips- it's well worth it to get an impact driver like this... http://www.bombaydigital.com/boxster...driver_lg.jpeg for removing the rotors. also the rear caliper pistons need to be reset by twisting CW as you press. there is a special tool for this, although i've gotten away with using a large prypar like a screwdriver. not always easy that way :crook:. there's nothing special really about brakes on this model. if you're familiar with brake jobs you'll have no trouble. :thumbup: |
I wish my CD5 was that setup. LOL. Is there a way to convert to newer setup?
(Post 46042118)
I was told that the Acura CL had the same setup as the Accords. They are pressed on also?
OP: here's a diagram of the front brakes. http://www.hondaautomotiveparts.com/...3s8201_b22.png here's a diagram of the rear brakes. http://www.hondaautomotiveparts.com/...8201_b1910.png |
ogsmakdade the brakes on the Accord are nearly the same as your Preludes.
(Post 46042118)
Originally Posted by JDM_DC4_FanaticParts:
1998 Acura 2.3CL Front Hubs OEM part # - 44600-YS8-A00
1998 Acura 2.3CL Front Rotors OEM Part # - 45251-S84-A01 1990-1998 Accord Front wheel bearing OEM Part # - 44200-SM1-008 1990-1998 Accord Front brake pads OEM Part # - 45022-SY8-A01 New cotter pins Nobody likes the FAQ anymore. |
(Post 46045525)
the process was the same as doing a brake job on my prelude. I replaced all four disks with brembo blanks, and used hawk hps pads. Hopefully my girl is happy with the setup.
I should have just jacked the car up and found out for myself but I was pressed for time. Thanks for all the positive responses guys, very helpful. this is why I did the work in the first place. crack all the way around the hub. http://i113.photobucket.com/albums/n...g?t=1316563420 |
Originally Posted by ogsmakdade
(Post 46049869)
Always do yourself a favor and leave the two screws off. They don't serve a real purpose.
Originally Posted by hondamark35
(Post 46049926)
so the rotor came apart in two pieces when you took it off!?
Originally Posted by holmesnmanny
(Post 46052259)
Originally Posted by MAD_MIKE
(Post 46045858)
https://honda-tech.com/forums/showthread.php?t=2027047 Nobody likes the FAQ anymore. |
(Post 46055851)
pretty much split all the way around, it didn't come apart when I took it off though. there was about an inch and a half that wasn't cracked, holding it together.
I always install brand new ones when I did the brakes on my lude. I installed them on all wheels accept the one with the split rotor on the accord. They wouldn't come loose, so I had to drill them out. However, I always wonder if maybe if you grease them good with brake grease before putting them on would guarantee them coming off later. Also, one thing I have also thought about is that perhaps they might help keep the rotor on straight as it's spinning real fast at high speeds even though the brake pads do keep it on straight. Just a little venting here. :) |
(Post 46058431)
That's why I leave them off.
However, I always wonder if maybe if you grease them good with brake grease before putting them on would guarantee them coming off later. Also, one thing I have also thought about is that perhaps they might help keep the rotor on straight as it's spinning real fast at high speeds even though the brake pads do keep it on straight. Just a little venting here. :) on the other hand though there's no shifting around of the rotor when the wheels are rotated if the bolts are used. they keep everything tidy and secure. :) |
What type of grease do you folks use for slider pins and back of shims? Does the CRC RED ANTI SQUEAK stuff last?
You talking about the spray stuff ? I use that on the back of my pads. I spray, let it dry, spray, let it dry until I have a few coats of it.
If you're talking about grease, you need high temp brake grease since cv axle grease will burn off faster. |
Nice job. What kind of difference did the brembo's and ceramic pads make? Bet it was significant.
