My all motor setup
94 Honda civic Ex
Jdm B16 stock head
B18c1 block
Ls rod
Ls crank
Rs Machine itr piston 81.5
Arp rod bolts
Ebay tri-y header
Tuned at 171Hp@129Tq at DB Performance
Gas E85
14.26 was the fastest this year was hoping at least 13.9 just need a little more time on the track
Next year mods
Skunk2 tuner stage 3 camshafts
valve spring and retainers
Skunk2 manifold or ITB
maybe 5 angle head job
Hoping to do Mid 12s
http://www.youtube.com/user/763yang?.../0/qIlk3rsxZpI
Jdm B16 stock head
B18c1 block
Ls rod
Ls crank
Arp rod bolts
Ebay tri-y header
Gas E85
Next year mods
b16 and gsr combustion chamber are different. b16 combustion chamber is bigger and gsr combustion chamber is smaller. but you can mill a b16 head to gain more compression too
b16 head
gsr head
b16 head
gsr head
lol.. ok.
Bigger is not always better. You don't have the mods nor airflow to support a tuner 3 camshaft. The overall better performing cam will be the pro1's, specially since this seems like it will be a street car..
8 more in the midrange will get you faster down the track then 5 @ peak.
tuner series camshafts retain "stock" primaries..with a huge *** vtec lobe. Pro series cams have modified primaries which are bigger then stock and produce better low/midrange without losing top end. The s2s2 and pro1 share close to the same vtec lobe..pro1 has a bit more duration i believe.
But you go with what you think is best.
lol.. ok.
itr chambers are almost identical to b16 heads (apart from some minor bowl work)
so the usdm ITR pistons net around 11:1 cr (11.3ish with JDM ITR pistons) in a straight ITR/GSR block with ITR/B16 head.
coupled with a 89mm stroke it ups the cr by another .2 cr.
increasing from 81 to 81.5 usually adds .1 cr
so let's say your at least @ 11+ cr
Im in the same boat as ALL_M0T0R. Pro 1's on this build would be killer. Im not a fan of the tuner cams myself since 90% of my driving is done out of vtec. Also I would look into the Performer X manifold over the S2.
I made 160whp untuned with a stock gsr bottom and and stock b16 head with stock cams, and hes got a higher C/R and a bigger motor and the tuner said he could have got 10 more whp out of my build.....and my car ran a similar times 14.5 @94.88mph but mines in a hatch so its a decent amount lighter (no ps/ac/power anything) so I could see alot of gains from a performer x or maybe a ITR because a performer x does make power but is a PIA to make fit haha. But with a performer x, pro1 cams, and a good tune 200whp shouldn't be a problem, but you also should look into a different header, at least a better knock off haha.
But mid 12's will be hard to do as people have said you better gut it and get some pretty good launching skillzzzzz (you prob. already have more then me but judging from your video you must have good tires or at least better then mine)
