Del Sol dies while driving
First off let me say hi I am the owner of a red 1993 del sol and a 1990 crx.
Now onto the problem I will be driving along in my del sol go to hit the gas and nothing happens. The engine is still running and when I hit the gas pedal a couple more times sometimes it will catch back and driving like normal or sometimes it will roll to a stop and then die. When this happens the car will sometimes start right back up or I will have to wait a while and then it will start.
I have checked I am getting fuel and spark the dizzy was changed two months ago but I checked the cap, rotor, igntion module, and ignition coil. I have checked and resoldered (just in case) my main relay. Replaced fuel filter and bought new ngk spark plug wires.
A little backround on my set-up d16z6 with greddy turbo kit running about 10psi tuned on crome with 440cc injectors and a walbro 255 fuel pump.
this happened to an old chevy of mine before i got into hondas you may need to replace your throttle cable it could be fraying and stretching instead of pulling your throttle open and then when u stop itll have set to far back into place and youll get no fuel and die if your throttle cable isnt bad... good luck someone probably knows whats up
The bolded text represents the opportunity to pinpoint the problem. When this happens, check whether there is bright white spark at the plugs and whether the fuel pump primes.
I do get spark when this happens and I do get fuel this is the weirdest issue ever so i took out my pcv valve and i have no idea when last it was changed (previous owner) it looked like it was filled with gunk and was for sure bad changed that and took the car out and no problems yet from what i know a bad pcv valve should not cause that kind of problem is it possible?
When the engine won't start, do the injectors spray fuel?
injectors were working and spark was nice and bright yesterday the only things I did was change pcv valve because it was clogged and adjusted my fpr but with my adjustment it ran to lean in boost so i brought it back to where it was. Now everything works fine no problems do you think the fpr was backed up or something
hexadec0079
Mar 4, 2014 09:36 AM
Carlos Peralta
Engine Management and Tuning
Oct 20, 2012 03:55 AM
OH_1fstgsr
Sep 25, 2007 04:25 AM
