B16a temp sensor broke off
Wow, if memory serves me right this is not the best places to work (tight). If you use an easy out it will be hard to work in the area, it needs to be drilled in the center and dead straight too.
Is the car running funny, any codes?
There are three temp sensors on your engine:
On the thermostat housing: The 2-wire temp switch
Under the distributor: The 1-wire temp sender unit for the cluster and the 2-wire temp sensor for the ECU
Which one are you talking about?
if its the one that plugs into the thermostat housing just get another one.
http://www.hondaautomotiveparts.com/...TAT+%28DOHC%29
you need part 5 - $11.20
and part 11 - $35.50
might as well get a new thermostat and gasket while ur in there. part 3 - $15.77
if its not that one , u either need part 10 or 12. and youre better off relocating it, instead of easy outting it out of the cylinder head. aluminum is weak.
joestud
Sep 14, 2013 01:58 PM
