97 Civic LX -- Which Headlights wires activate high beam
Old Sep 17, 2011 | 10:42 PM
Wrona's Avatar
Default 97 Civic LX -- Which Headlights wires activate high beam
ok so i am trying to hook up the high beam on my 97 CIVIC LX and which wire is the power and which wire is the ground for the high beam i have the aftermarket headlights and i am trying to figure out which one is which so i can get it running i decided to ask first at night before going at it with a multimeter in the morning does anone have the diagram?
Old Sep 17, 2011 | 10:53 PM
MRGRIM's Avatar
R.I.P. Mark
Default Re: Which Headlights wires activate high beam
this should help you
Old Sep 17, 2011 | 10:54 PM
Wrona's Avatar
is the red blue wire like in this diagram the high beam?
Wrona's Avatar
sweet bro thanks
Old Sep 17, 2011 | 11:04 PM
MRGRIM's Avatar
R.I.P. Mark
no probs
glad to help
Old Sep 17, 2011 | 11:11 PM
Wrona's Avatar
no probs
glad to help
so i went out to try to rig up my high beam and i have
these in my high beams when i tried to flash my high beam all that would flash is my low beam both of the bulbs seem not to light up could it be the bulb or a fuse because the bulbs look brand new inside
Old Sep 17, 2011 | 11:22 PM
MRGRIM's Avatar
R.I.P. Mark
check your fuse 1sst
Old Sep 17, 2011 | 11:37 PM
Wrona's Avatar
will do tomorrow check back with u tmm
Old Sep 18, 2011 | 06:49 AM
Former User's Avatar
Default Re: 97 Civic LX -- Which Headlights wires activate high beam
Stock power wire for high beams:
Right = Red/Blu
Left = Red/Grn
Old Sep 18, 2011 | 08:00 AM
sde780's Avatar
H4 headlight wiring is weird. I had to buy a relay harness from theretrofitsource.com to get my high beams working properly - I couldn't activate the high beam solenoid in my projectors following the pictures posted above, because when the high beams are turned on I believe the low beams turn off, which turn off my HID bulbs.
Old Sep 18, 2011 | 12:54 PM
Wrona's Avatar
what adapter is it because i cant get the bulb to work in my headlights i did everything i can think of
Old Sep 19, 2011 | 03:00 AM
sde780's Avatar
You've got separate high beams now? Make a harness like the pic above or buy the H4 relay harness off theretrofitsource...its $30 though I think
pjr710
Jan 11, 2025 08:19 PM
crxsleeper210
Apr 9, 2009 06:09 PM
aoshiblade
Oct 23, 2006 10:44 PM
ToitelStilz
Audio / Security / Video
Apr 18, 2005 06:05 PM
